infinitefoamies Posted April 21, 2016 Report Share Posted April 21, 2016 I am looking for a dual concentric pot with the center shaft also operating a push button. I will be modifying a factory HU for my 71' K10 Suburban to control items such as trailer brake controller, winch, fuel tank valve, glow plugs, etc and need the extra controls in the standard knobs. 1971 K10 Suburban - Chummins 1973 MG B GT 1981 Tartan 3000 1988 F350 XLT Lariat IDI Link to comment Share on other sites More sharing options...
Wehan Posted April 21, 2016 Report Share Posted April 21, 2016 http://www.digikey.com/ If they don't have it it probably doesnt exist. Link to comment Share on other sites More sharing options...
infinitefoamies Posted April 21, 2016 Author Report Share Posted April 21, 2016 Well it looks like I will have to make one. 1971 K10 Suburban - Chummins 1973 MG B GT 1981 Tartan 3000 1988 F350 XLT Lariat IDI Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted April 21, 2016 Report Share Posted April 21, 2016 Will it still be able to play music after all the other stuff it has to do? You would be better off having a dedicated switch panel to do what you want. The last thing you want to do is hit a bump when you are trying to activate your gadget and get the wrong one. Or even just forget what does what and hit the wrong thing. Your idea sounds cool but not practical. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
infinitefoamies Posted April 22, 2016 Author Report Share Posted April 22, 2016 Will it still be able to play music after all the other stuff it has to do? You would be better off having a dedicated switch panel to do what you want. The last thing you want to do is hit a bump when you are trying to activate your gadget and get the wrong one. Or even just forget what does what and hit the wrong thing. Your idea sounds cool but not practical. I don't blame you for thinking this, but if you knew me, my current truck has a switch panel with ~16 unlabeled switches and I almost never get the wrong one A dedicated switch panel will not allow me to keep the dash looking 100% factory. I had no intentions of using a factory radio to the point I got a factory radio delete plate and am making a custom tray for a modern HU + CB radio + HAM radio that will retract under the dash with additional switches for equipment. So no need to worry about it playing music though I think I will use one knob on it with the 'steering wheel control' volume for the modern HU so when it is behind the dash I can still control volume. I do appreciate the concern however. 1971 K10 Suburban - Chummins 1973 MG B GT 1981 Tartan 3000 1988 F350 XLT Lariat IDI Link to comment Share on other sites More sharing options...
3vil Posted April 22, 2016 Report Share Posted April 22, 2016 You might have some luck walking a junkyard and salvaging a pot/switch combo form some other factory radio. Link to comment Share on other sites More sharing options...
infinitefoamies Posted May 5, 2016 Author Report Share Posted May 5, 2016 What my latest plan is, is to mount the dual pots on a sort of spring loaded slide with a PB behind them. No one besides me will know the difference. 1971 K10 Suburban - Chummins 1973 MG B GT 1981 Tartan 3000 1988 F350 XLT Lariat IDI Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted May 5, 2016 Report Share Posted May 5, 2016 I've seen someone use an arduino with a little screen in the factory radio to do something like this, You can program the arduino to respond to button pushes and turns how ever you'd like. Might have been on mcm, I'll see if I can find it. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted May 5, 2016 Report Share Posted May 5, 2016 Start at 25:45. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
