SlamminBeats Posted May 19, 2016 Author Report Share Posted May 19, 2016 I'm beginning to feel like the world is against you having bass in this vehicle. its because of how picky i am! I dont want to lay a box in the trunk, it will never work and ill have to fold seats down, plus in this car i want to add weight. Can someone maybe recommend decent 6.5 subs that can play low in a rear deck lol? Arent the CDTs supposed to work for that? Link to comment Share on other sites More sharing options...
STEvil Posted May 19, 2016 Report Share Posted May 19, 2016 add panels to ski hole so it becomes a port, mount subs to the panels. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed. Link to comment Share on other sites More sharing options...
SlamminBeats Posted May 19, 2016 Author Report Share Posted May 19, 2016 Thats what im trying to figure out now. How can i secure wood to ski hole without drilling into the seat Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted May 19, 2016 Report Share Posted May 19, 2016 There should be metal braces behind the seat and the rear deck should extend behind the top of the seat as well. This is what you would mount the baffle to. If the ski hole is smaller than the sub it will still work. It won't be much of a port but more like a big hole the sub plays through. Is it ideal? No. Will it work? Yes. It is the result of the compromises you are willing to make to get what you want. I say go for it. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
jk13 Posted May 19, 2016 Report Share Posted May 19, 2016 Thats what im trying to figure out now. How can i secure wood to ski hole without drilling into the seat What are the dimensions of the ski hole? Could you build a box that fired a stout 10" or 12" through the hole and had external ports to the 6x9 openings? It would be much smaller than the bandpass discussed elsewhere. Static drops are my bag. Link to comment Share on other sites More sharing options...
SlamminBeats Posted May 19, 2016 Author Report Share Posted May 19, 2016 Ski hole is 9x7. I want to mount it so the seat folds down and takes the woofer with it. I think a 10" sub would work in this fashion. It would be rear mounted. Maybe i can put a screw throuw the wood and attach to the back seat metal brace. Link to comment Share on other sites More sharing options...
OrionStang Posted May 19, 2016 Report Share Posted May 19, 2016 I want to mount it so the seat folds down and takes the woofer with it. SHit just got a lot more complicated LOL. I honestly think you want too much from too little. SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
SlamminBeats Posted May 19, 2016 Author Report Share Posted May 19, 2016 This thread is what i am visualizing. http://forums.swedespeed.com/showthread.php?200578-Notes-and-photos-on-adding-sub-woofer-and-digital-signal-porcessor-(DSP) I think a 10" sub would work. It would be rear mounted so its recessed back 1" from the square baffle that mounts to the ski pass. The whole thing is shorter than the seat so it can fold. Link to comment Share on other sites More sharing options...
OrionStang Posted May 19, 2016 Report Share Posted May 19, 2016 So the only question is how to attach to seat without screws? Got a pic of the back side of the skihole? SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
SlamminBeats Posted May 19, 2016 Author Report Share Posted May 19, 2016 ill have to upload when i get home. Link to comment Share on other sites More sharing options...
