Kicker CX1800.1 (43CXA18001) {2016 CX Series}
Kevin Wright
IMG_20160621_131635.jpgIMG_20160621_131644.jpgIMG_20160621_131639.jpgIMG_20160622_031506.jpgIMG_20160622_031932.jpg
Current System
Deck:
Pioneer DEH-80PRS (3-WAY ACTIVE)
Incriminator Audio 3.4 4 Channel (75x4 @4 ohm)
(2) NVX X-Series Active Tweeters
(2) SB Acoustics SB16PFC25-8 6" 8 ohm Paper Cone Woofers
Subs:
(2) Sundown Audio SA-12's
Amp:
(1) Kicker CX 1800.l (43CXA1800.1) 2016 Model
(It is rated 1800 @2 ohm but I have it running at 1 ohm, does a little over 2500!)
Big 3 w/ 1/0 gauge wire
(1) XS Power D4800 under the hood
(1) Duracell Group 31 Deep Cycle
(4) Runs of KnuKonceptz Kolossus Fleks Kable (2 pos, 2 neg)
(1) KONfused 4-way Power and Ground Block
Alternator:
DC Power XP 270 High Output
Anybody care to give some insight on this board. I've been considering it real hard for my 2 12" sa subs because they are dual 2 ohm. Either that or go with crescendo, sundown, or twisted sounds and run them half ohm.
Where are all the power chips
OH and I just read where you say it's at 1 ohm doing around 2500 watts. How do you know? Did you clamp it? Or was it tested on a synonym?
I clamped it using a 1 ohm resistor and my mini oscilloscope. It did 65 Volts and I got 38.5 amps. Battery voltage dropping down to 13.9. It only recommends a 150 amp fuse but that is at 2 ohms. I popped it during the test and replaced it with a 250 amp fuse, since it is at 1 ohm. I have been using it daily for 3 days and it hasn't gotten hot at all so far.
Current System
Deck:
Subs:
Amp:
Alternator:
So you have an o scope? Did you set your gains with the o scope before you clamped it?
This amp.would solve a lot of issues for me. I've got the cx-1200.1 which is the older model but same series. I also have the cxa-300.4 on my minds and highs. It works great for what I have.
The subs just seem underpowered. I've seen my amp dyno'd at right at 1200 watts. So I know these amps can do rated. I also saw it do over 1500 at 1 ohm.
  • Who's Online   1 Member, 0 Anonymous, 1547 Guests (See full list)
