mike-g Posted June 26, 2016 Report Share Posted June 26, 2016 I have been modeling this sub in winisd and i'm not sure what will work well,plus have port velocity's around 17 m/s,i can use the hp,lp filters to get the velocity down without making the port larger,not really sure what i should consider good though.i was trying to share what I've modeled to make it easier and maybe have one of y'all explain what would work so i don't have to ask someone to model every time.i almost understand what i'm doing,but not 100% so was hoping someone could model a vented qb3 quasi butter worth,& c4/sc4 sub chebyshev or what what ever you think would have the best results.i listen to a lot of rebassed music,rap,rock,country from 25ish hz & up.i actually have 2 of these txl,but only have 2 crossfire bmf1000's 2k@ 2ohm strapped so ill only be running one for now. please and thank you in advance vehicle-2000 Buick park avenue sub back,port back,possible sub back port through rear deck if anyone thinks that would do well amps-2 crossfire bmf 1000 2k@2ohm strapped trunk measurements-? haven't gotten their yet,i can come up with design if someone will model and give their recommendations sub rms-2500watts T/S Parameters Re : 2.0 Ohms Fs : 41.1 Hz Qms : 5.46 Qes : 0.55 Qts : 0.50 Spl : 89.8 dB Mms : 290.0 gr Res : 136.3 ohms Nref : 0.61 % Rms : 13.7 Kg/s Cms : 0.05 mm/N Lp : 14.8 mH Rp : 19.4 ohms Vas : 49.8 L Cp : 1410.9 uF Le : 1.05 Bl : 16.5 Xmax : 55.0 mm also if someone models this and would be able to explain what to look for when modeling with winisd would be very appreciated.thank you Link to comment Share on other sites More sharing options...
mike-g Posted June 26, 2016 Author Report Share Posted June 26, 2016 Link to comment Share on other sites More sharing options...
mike-g Posted June 26, 2016 Author Report Share Posted June 26, 2016 If someone could explain how I should do the criss section if the port,versus port velocity, I could probably get it done without anyone modeling it Link to comment Share on other sites More sharing options...
mike-g Posted June 26, 2016 Author Report Share Posted June 26, 2016 What I mean is cross area is 68.15", 14.5 x 4.70. Enclosure is 4.407cuft with 31hz tunning,I have port velocity at 25.419 m/s @27hz max velocity. Link to comment Share on other sites More sharing options...
mike-g Posted June 26, 2016 Author Report Share Posted June 26, 2016 That's port velocity with a 80hz highpass filter, it took port velocity down to 2 m/s @28hz,I don't think I'm doing this right,also what kinda cross area should I be looking for with 1 15? Link to comment Share on other sites More sharing options...
