JerryLZ Posted June 27, 2016 Report Share Posted June 27, 2016 I'm running (4) RF Punch P1683's. I would like to get a amp on these speakers finally but I don't know much about mids and highs so thats why I'm here Preferred brands would be Sundown or RF but I'm open for suggestions. These call for power range: 6-65 watts RMS (130 watts peak power) Side note: I remember seeing something awhile back that was basically a harness that made it easy to run your speakers back to your amp without needing to run wire to each door individually (connected to headunit harness) . Is this a viable option for speakers in my power range? Link to comment Share on other sites More sharing options...
300824 Posted June 27, 2016 Report Share Posted June 27, 2016 http://www.ebay.com/itm/CT-Sounds-125-2-amp-amplifier-125w-RMS-250w-MAX-Class-A-B-2-Channel-2-Ohm-/121972989443?hash=item1c66281e03:g:w5IAAOSwJb9WrS7C thank me later!!! :-> Link to comment Share on other sites More sharing options...
JerryLZ Posted June 27, 2016 Author Report Share Posted June 27, 2016 http://www.ebay.com/itm/CT-Sounds-125-2-amp-amplifier-125w-RMS-250w-MAX-Class-A-B-2-Channel-2-Ohm-/121972989443?hash=item1c66281e03:g:w5IAAOSwJb9WrS7C thank me later!!! :-> Looks decent, I figured I would need a 4 channel amp since I have 4 speakers so whats the difference between 2 and 4 besides obviously channels? Would I need 2 of these? I know my speakers are 4ohm, just trying to figure out in my head how this would be wired up. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted June 27, 2016 Report Share Posted June 27, 2016 You could do either. 4 channel would give you fade/balance capabilities. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
_paralyzed_ Posted June 27, 2016 Report Share Posted June 27, 2016 When you run two 4 ohm speakers in parallel you get a 2 ohm load.You can use a 2 channel amp for all 4 speakers. Front and rear left on the left channel, F & R right on the right channel. You will not be able to fade from front to rear like this. You need a 4 channel amp to retain the fader control. Link to comment Share on other sites More sharing options...
Mariothadon Posted June 27, 2016 Report Share Posted June 27, 2016 You could do either. 4 channel would give you fade/balance capabilities. I'd go with a 4 channel if I was him. Don't want to lose those capabilities. Link to comment Share on other sites More sharing options...
Skullz Posted June 27, 2016 Report Share Posted June 27, 2016 http://www.sonicelectronix.com/item_38338_Precision-Power-PPI-P900.4.html 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
JerryLZ Posted June 27, 2016 Author Report Share Posted June 27, 2016 http://www.sonicelectronix.com/item_38338_Precision-Power-PPI-P900.4.html Thanks for the input but I think I'm going to avoid ppi again. I was using a 1000.1 for my subs before I upgraded to my new scv2k recently and I had to Dremel off those bars that cover the screw holes and even then the screws were off center from where you could reach with a screw driver so you lose your bite or you strip the screw to hell. If It was Allen keys instead of Philips then maybe not so bad but definitely a odd set up that I'm not willing to deal with again. Link to comment Share on other sites More sharing options...
Masterbasser Posted July 2, 2016 Report Share Posted July 2, 2016 those bars are removeable for installation lol. Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl Link to comment Share on other sites More sharing options...
islandpride684 Posted July 3, 2016 Report Share Posted July 3, 2016 those bars are removeable for installation lol. Lol did he really??? No way he did not know that....funny shit Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
