sTp Posted July 16, 2016 Report Share Posted July 16, 2016 Hi guys i am looking for a box design for a RF T2D415 will be powered from a T1000-1bdcp main music i listen to is Drum and Bass and decaf want it to be able to play the lows if possible. Hear are my max dimensions: Height = 45cm Width = 104cm Depth = 43cm i Have worked out the volume of the box is around 5.50 cuft if the box needs to be made smaller shrink the width if possible. Link to comment Share on other sites More sharing options...
sTp Posted July 22, 2016 Author Report Share Posted July 22, 2016 Still looking for a design for the specs above if possible need a design by the weekend as wanted to start building ASAP. Link to comment Share on other sites More sharing options...
sTp Posted July 30, 2016 Author Report Share Posted July 30, 2016 Bump still looking for a box design? Link to comment Share on other sites More sharing options...
Kyblack76 Posted July 30, 2016 Report Share Posted July 30, 2016 I won't get into enclosure help, but man, I'd put a 2500 on each of those. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
sTp Posted July 30, 2016 Author Report Share Posted July 30, 2016 why would you put 2500 on them its only the old style T2 and its only one sub this one http://www.rockfordfosgate.com/products/details/t2d415 Link to comment Share on other sites More sharing options...
Kyblack76 Posted July 30, 2016 Report Share Posted July 30, 2016 I though I read you had two. It is 4" coil, I'd still run a 2500 on one. There is a member here that did it already. He liked it. Sorry to muddy your thread/question. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
sTp Posted July 30, 2016 Author Report Share Posted July 30, 2016 Np buddy just looking for help on a box design i built one a while ago but was abit on the small size just want to get the most out of the sub but don't want to damage it. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted July 31, 2016 Report Share Posted July 31, 2016 I've seen them take a 2500cp 3 cuft with a 50-70" port area tuned to 33-35hz would be my suggestion on the 2500. I'd aim for 33hz and if I felt like the box was to big for how much power it's getting add some wood on the box and drop the volume to 2.75 tuning would still be under 35hz I'm going to be doing 2 of them on a 1500bdcp each. 3.5cu each with 120" of port area tuned to 34hz. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
sTp Posted July 31, 2016 Author Report Share Posted July 31, 2016 Right as im only going to using a T1000-1bdcp as that's the only amp i have got atm and not looking to upgrade for awhile what size box would you recommend i have a total of 5.50 cuft to work with. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted July 31, 2016 Report Share Posted July 31, 2016 I hinted around the box volume you would want. If on more power you would want around 2.75-3 then on less power you need a ---- box t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
