Help needed installing amps in a 2016 Silverado
Chances are you have a wiring issue or the loc can't handle the factory Bose amp.
Could be a bad loc to
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
If by 'cutting out' you mean shutting off and you're tapped in after the Bose amp with a cheap non-adjustable LOC you may be overdriving the LOC or your amp's input stage.
If by 'cutting out' you mean the bass gets quieter as you turn it up but keeps playing, that is a nanny function of the Bose system and is there to protect their factory 4 or 6" subwoofer. The only way to really get rid of it is with a new source unit.
Like said above, give ALL the details. How many channels of LOC? Just four, or one on the OEM sub channel as well? Which LOC is it, exactly? Tapped in before or after the Bose amp?
Static drops are my bag.
  • Who's Online   1 Member, 0 Anonymous, 1196 Guests (See full list)
