Jessica Posted August 15, 2016 Report Share Posted August 15, 2016 lol, i almost certain i fucked up a spider on one of mine by overpowering/low notes. Gonna pull it this week and check. Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
loosescrew Posted August 15, 2016 Author Report Share Posted August 15, 2016 I am going to run 2 x15s on a scv6k @1ohm.im not going to clipp the signal.even if the clipp indicators flash a little ima turn it down so they don't.im going to build a wall with port in middle of box and separate the port in the middle so 2 subs in each box are not fighting to push thru one opening.8.5 cubic feet for 2 15s ported to 30hz.box will be very thick and fiberglassed.im going to set the subsonic filter to probly 25 or 28 because of the power im runing .I have 2 x15s in a 10 cufoot box now tuned to 26 or 28 hz now.when I finally get the scv6k in I'm going to try it in the box I have em in now.but also I only have a 240 mechmans and 1 yellow top.so was thinking put another 240 in and 2 xs d3400 and see how it handles.ill have time before the scv comes in to get my electrical up for the one 6k.also I'm on YouTube as mike renza.thers 2 on ther ther both me so check both cuz I will put it on the and the new build I'm going to do.and yes I'm going to clean up the mess I put together before the new box wall Quote Link to comment Share on other sites More sharing options...
Smoove Posted August 15, 2016 Report Share Posted August 15, 2016 why not get 2 xp3000's instead of 3400's and if you can get a 300+ amp hairpin altdepending on rise and voltage drop might be able to get away with an scv6k Quote 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
loosescrew Posted August 15, 2016 Author Report Share Posted August 15, 2016 Ima check the xs3000 out.they better? Was thinkn 4 batterys to.and the bracket I'm build for my car for alts is gonna take some time I have to modify alot of shit find different size pulleys and finding a belt to fit that's long enough or the right size is going to be hard.i looked at gates belts and the sites very confusing.wish they had options for different length size belts that is simple to look at I could order a large case 370 amp alt but id still need 2 more 240s Quote Link to comment Share on other sites More sharing options...
loosescrew Posted August 15, 2016 Author Report Share Posted August 15, 2016 When I build my alt bracket I need help on finding a belt to fit Quote Link to comment Share on other sites More sharing options...
Jessica Posted August 15, 2016 Report Share Posted August 15, 2016 buy some twine, run it around everything, mark it, lay it out and measure. You may need someone to hold a tensioner down while you do it. but that is the simplest way 1 Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Smoove Posted August 15, 2016 Report Share Posted August 15, 2016 with a mechman 370 hairpin and 6 rear batts I hold 12.8v hammering at idle on an scv6k 1 Quote 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
SubbinNCali Posted August 15, 2016 Report Share Posted August 15, 2016 I'm running two X 15's on a SCV6K in my bug. I baby my system and rarely play it hella loud for an extended period of time (1hr +) and they barely warm to the touch. Gains are set with a DD-1 and using a PAC LC1. 1 Quote Link to comment Share on other sites More sharing options...
loosescrew Posted August 15, 2016 Author Report Share Posted August 15, 2016 IV got recone info .cuz I no I'm gonna wana see what it can do..ordering last 6k Tuesday then I'm going to work on alternators batterys and wire.gonna take little while Quote Link to comment Share on other sites More sharing options...
