Ok so I'm out here and it is making noise with the engine off and stereo on, a hum noise and if I shut door or anything it makes noises
Shoot a video real quick of what it sounds like, also just cut the black (ground) wire from harness, connect a ring terminal at the end (connect to wire coming from headunit) and find a good metal contact behind the headunit and ground it there...is there noise when the rcas are unplugged from the amp?
Ok lets go back to the beginning. In post #8 you unhooked the rcas from the amp and the problem stopped.
Pioneer 80PRS
Turn your gain all the way down and lets do this one step at a time.
Pioneer 80PRS
Turn your engine on with amp on and the rcas unplugged from the amp. Any noise?
Pioneer 80PRS
Is the gain turned all the way down?
Pioneer 80PRS
