00 s10 ext cab sub help
I have 2000 s10 ext cab and currently have mtx 1501d thunder no elite amp with 2gauge wiring,200amp ad244 alt,2-10" re audio sxx in 34hz tuned box with 3.30cubic ft shared.. well one sub that was older then other has started popping on low notes and cant turn it up no more.. question is for the money would the soundqubed hds200 10" dual 2ohm 600rms would that be just as loud as my setup when first installed? Or should i go to the hds300 10"s and be just as loud but with potential of adding a aq2200 or something later? Im stuck what to do and never owned the aq just heard and seen youtube of them
Thanks sorry for long post
----------- no more blazer-------------
New ride 2000 s10 ext cab xtreme zq8 v4a
4.3 jba headers,pcm4less tuned,nv3500 5spd,8.5" diff,ported/polished heads
makes good daily driver not a racecar lol
system:
pioneer 7200hd deck,kenwood kfc708 with jl xd400.4
stinger 2gauge wire
mtx thunder 1501d
custom built box myself ported 3.13 slot port 40hz (2) 10" re audio sexv2d2- may do sxx upgrade soon after tune the sex first
kicker 4x6 cs dash.
Never run 2 different subs in the same box. Never ever ever..... ever. They will destroy each other. That is why your older one is having problems. Chances are there was a design revision between the new one and the old one and the T/S perimeters changed.
okay makes since, i hope i didnt make a mistake i ordered two hds210 soundqubed today but now i feel like i would of wanted to get anouther amp , maybe sq 2200 but then again im not doing competitions so maybe with about 700rms to each after breakin they may do preety good. Thanks guys
system:
stinger 2gauge wire
mtx thunder 1501d
kicker 4x6 cs dash.
  • Who's Online   2 Members, 0 Anonymous, 1323 Guests (See full list)
