gamerdude2956 Posted August 29, 2016 Report Share Posted August 29, 2016 So my setup consists of two Alpine type R's and right now powered off a car amplifier in my home and as you can already guess that is not a sufficient way of powering these sine the amp is only running off a 40Amp power supply not a 300amp alternator. So my question is if i want to buy a PA amplifier and im looking at Crown, which should i buy? Crown XTi? I'm lost which are which. Each subwoofer is only 1000w RMS I already have a gemini PA amplifier for my Crescendo 8" mid drivers and the whole mix board and cross over. Just need a new amp to get the full potential of my subwoofers? The subwoofers are currently both in a large box but soon i'll be building two separate larger boxes that are to spec for the CuFT and place each box in separate corners of the room. But Just need to start with the amp upgrade. So if anyone has a suggestion hmu. My behringer crossover only has a single subwoofer output running from XLR to rca for my current amp so not sure how some of those dual xlr amps will connect to my crossover so ill need an answer for that.. I'd also like to leave enough power room for Steve's new subwoofer line-up whenever he releases those mini 12"s ill be ordering a pair, and i think he said in a video that each subwoofer would be about 1600W but i may be mistaken. The car amp im using is the CAB (Car Audio Bargain) amp that Steve did a review on, which delivers on the book 1600W but we all know now that it delivers way more than that when you're actually powering it correctly. Sorry for such a long post. Just trying to get all the questions out in one post. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 29, 2016 Report Share Posted August 29, 2016 I use the inuke 6000 four channel. It can do 2 ohms or you can bridge it on 4 ohms. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
zoeboi954 Posted August 29, 2016 Report Share Posted August 29, 2016 Crown amps are expensive if you are sure that you want to go down this route. The best amp for the best price that i see is the XTi 2 4002 which offer an xlr input and deliver 1600w @ 2ohms,1200w @ 4ohms,650w @ 8ohms. But im not to sure of this is considered rms or peak power. Another one is the CDi 4000 it delivers the same output as the XTi 2 4002. But its input out seems to use some type of wire harness. Both have a higher models if you want more power. XTi 2 amps http://www.crownaudio.com/en-US/product_families/xti-2-series CDi amps http://www.crownaudio.com/en-US/product_families/cdi-series 4 Fi Q 12s In A Prius on 4 Crescendo BC2000D?! That's Absurd (!!!UNDER CONSTRUCTION!!!) go follow http://www.stevemeadedesigns.com/board/topic/190658-the-first-prius-with-4-12s/ Link to comment Share on other sites More sharing options...
gamerdude2956 Posted August 29, 2016 Author Report Share Posted August 29, 2016 Well XTi sounds like the better option, but are the wattages per channel? Or is it talking like 1000w split for two channels? That's where im confused with these amps. If i look at bridged it says 2000w (talking about the XTi 2002 model). Well lets just say forget about the Alpine subs because i'll be getting rid of them as soon as i get my hands on the mini 12"s So what ohm are his new subs going to be? If Crown maybe isnt the right way to go so i wouldnt be spending 1k on just an amplifier what other brand would someone suggest? Not making this a vs post but still just curious what other options. New to the pro audio stuff, but also know what im doing. Link to comment Share on other sites More sharing options...
bmwking Posted September 7, 2016 Report Share Posted September 7, 2016 Well XTi sounds like the better option, but are the wattages per channel? Or is it talking like 1000w split for two channels? That's where im confused with these amps. If i look at bridged it says 2000w (talking about the XTi 2002 model). Well lets just say forget about the Alpine subs because i'll be getting rid of them as soon as i get my hands on the mini 12"s So what ohm are his new subs going to be? If Crown maybe isnt the right way to go so i wouldnt be spending 1k on just an amplifier what other brand would someone suggest? Not making this a vs post but still just curious what other options. New to the pro audio stuff, but also know what im doing. iNuke3000dsp Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted September 7, 2016 Report Share Posted September 7, 2016 iNuke3000dsp This "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
Wehan Posted September 11, 2016 Report Share Posted September 11, 2016 I've read the inuke 3000 doesnt like to do 2ohm and the 6000 doesnt like to do 4 ohm at full output and they tend to trip into shutoff protect when doing so. I'm looking at the Crown XLS 2500 to run my FI ssd's (wired at 2 ohm each) Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted September 11, 2016 Report Share Posted September 11, 2016 The iNuke 6000 four channel will do 2 ohms on each channel. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Wehan Posted September 12, 2016 Report Share Posted September 12, 2016 Also a nice line is the XLS DriveCore 2 series, they have rca inputs and can be switched between 1.4vrms (pro level input) or .775vrms (home equipment level input) so you dont have to spend extra on a small mixer or line driver to get full potential out of them plus the remote trigger connection is a super nice feature especially if you home receiver has a trigger output so you can leave the amp on all the time and it will turn on and off with the trigger signal from your receiver after some rigging with a relay or trigger box. Link to comment Share on other sites More sharing options...
