The way I would wire would be on each sub wire the + from one coil to the - of the other coil. Then the left over + and - that aren't wired together on each sub will go into the amp from each woofer keeping both +'s and -'s from the two subs together in parallel.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
This way of wiring the subs is called a series parallel configuration. Meaning that the coils on each sub are wired in series and then the two subs are wired in parallel to get you to your 1 ohm load.
1 XS Power D3100
Audio Control LC6i
Stock Deck
so will i have 4 runs in to my amp if i wire It this way?
In your case just substitute the 2's with 1's
I found this on this magical thing i use to search the internet called GOOGLE
Edited by Markous
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
  • Who's Online   0 Members, 0 Anonymous, 680 Guests (See full list)
