Loudness setting
Hello,
I know loudness clipping, but without him, bass is weak, car is saloon if relevant, what would you recommend to me, the system is so configured for now (Sorry for bad english)
Cd Player Setting
EQ: Flat
Loudness: HI
sub w ctrl: 80hz : 0: -12
HPF: 80hz : -12
S. Rtrv: Off
Mono Amp Setting
Gain: 1/2 Normal(2V Standard 500 mV)
LPF: Cd Player Filter 80 hz
Bass Boost remote control: MIN(Off)
Loudness on most head units is usually effective at low to mid volumes. At high volumes many head units automatically shut loudness off.
What equipment are you using?
What Head Unit?
Are you using RCA cables?
What Speakers?
What Subwoofer(s)?
What Amplifier(s)?
What Size Power and Ground Wires?
With no music playing, find out how high your volume goes on your head unit. i.e. Max volume = 30 or 60 or 100. For ease of helping you lets say yours goes to 60 at max volume.
Set all your sound settings to flat on the Head Unit, make sure loudness is OFF, if the head unit has subwoofer controls, set them to 0 and turn everything down on your amplifier that the sub is connected to.
Now, get test tones. Find a 40hz test tone recorded at 0db and one recorded at 1,000hz also at 0db. If your volume goes to 60, set it at 50. Now lets start.
Put in the 40hz test tone, pause the track, set volume to 50, set track to repeat, get ready to adjust the gain slowly. Push play!! Now adjust the gain until it sounds good to your ear. Stop!! disconnect the RCA's for the sub.
Now on to the mids and highs. Put in the 1,000hz test tone, pause the track, set the volume, set to repeat, get ready to adjust the gain... push play. Adjust the gain for the mids and highs untill they are loud and clear. Stop. Lower the volume on the head unit. Re-connect the sub amp. Put in some familiar music. Adjust the EQ settings on the head unit, adjust any additional settings for sound on the amplifiers. You should now be able to turn your head unit volume very loud without distortion and you should now be able to use your sub more effectively.
Kenwood Excelon KDC-X998
JBL GTO608C Components
JBL GTO628 Coaxials
JBL P1224 12" dual 4ohm Subwoofers
Alpine MRV-F545 - Alpine MRX M100
Hand Built by Me 5.9cu.ft. slot ported enclosure tuned to 27hz
What Head Unit?
What Speakers?
What Subwoofer(s)?
What Amplifier(s)?
Cd player: Pioneer deh-3500ui
Monoamp: Pioneer d9601
Subwoofer: Pioneer ts-w3004spl
Box: Ported Box
Capacitor: 2F
Power Cable: 25 ft
RCA Cable: blue thick
Mids and highs no problem, max volume on cd player is 62
What I mean is 1/2 doesn't mean anything, it doesn't tell us anything. It's not 1/2, because would indicate that the knob turned all the way to the right is full, it's not. For instance, my gain setting is about 1/3 of the way turned, but the amp is running full output. the only thing that we can deduct from your gain setting is that your RCA voltage is about 1/2 of what the amp can accept, and even that is largely a guess.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
What Head Unit?
What Speakers?
What Subwoofer(s)?
What Amplifier(s)?
Box: Ported Box
Capacitor: 2F
Power Cable: 25 ft
Not terrible stereo components at all. Set your gain as i said above with your volume at 52. This will give you some wiggle room when adjusting audio settings after you set the sub amp gain. MAKE SURE YOU HAVE THE VOICE COILS WIRED CORRECTLY!!! If that is the dual 4 ohm voice coil model then you could have it at 8 ohms or 2 ohms running a single sub.... Run it at 2ohms If you want it to be louder... check those coils first!
JBL GTO628 Coaxials
It connected the picture 2 ohms
You mean that your gain is max and cd player increases, decreases according to taste, because turn off loudness and bass low not hear even volume to 30-40, because I've heard gain setting more than 1/2 leads to clipping ?
  • Who's Online   1 Member, 0 Anonymous, 1171 Guests (See full list)
