HDanielh Posted October 11, 2016 Report Share Posted October 11, 2016 (edited) About a second after I turn off my car there is a popping noise as the system shuts down. Clearly audible but not real loud. I think it may have something to do with the 3sixty.3 problems I had. Some kind of power feedback? current system, I left the factory system in the car with only one center dash speaker because of the number of things that touch screen controls and does., nav, sirus link, ac/heat controls and even how lights work in the car, ect. Current system mostly Rockford Fosgate ; PMX-2 head unit because it fit in a spot I wanted to put it. t2500 on 2 psi stage 3 subs t1000.4 bridged for front doors pps10-4 t1000.4 bridged for back doors pps10-4 t600.4 for door tweets pp4-nt t400.2 for dash memphis mojo tweets 3sixty.3 audio control in dash epicenter audio control four:one RF 10 farad cap 4/0 big 3 plus 2x 4/0 to trunk Rockford and Knukonceptz wire 3x optima red tops 320 amp alt Everything sounds awesome. The only problem is that pop when I turn off the car. I was hoping that would go away with the new head unit but it is unchanged. I tried without the cap. I made sure all grounds are good, bolts/nuts, scraped paint, tight everything with every battery grounded to the car body and the underside of that bolt going to a bolt in the frame with a 1/0 just to be sure. None of my grounds have over 5 ohms resistance. Edited October 11, 2016 by HDanielh Quote Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted October 11, 2016 Report Share Posted October 11, 2016 Do all the speakers make the pop or just the subs? Try unplugging the rcas from the amps that pop to see if it is coming down the rca line. Quote 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
bsneon98 Posted October 14, 2016 Report Share Posted October 14, 2016 x2 is it just subs? Quote Build Log: http://www.stevemeadedesigns.com/board/topic/152954-1998-plymouth-neon-updates/ Link to comment Share on other sites More sharing options...
Soccerballzs Posted October 14, 2016 Report Share Posted October 14, 2016 you are using a 3 Sixty 3 for sub plus a Audio Control Epicenter? If so lose the AC Epicenter and see if it stops. I would only run the 3 Sixty 3. Do away with unwanted fixtures. Quote http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/ Link to comment Share on other sites More sharing options...
Rich Schenk Posted October 14, 2016 Report Share Posted October 14, 2016 Start bypassing equipment and see how if it goes away could be epicenter or audio control 4. Where our u hu, epicenter, and 4 grounded too, where our your amps grounded 2? Quote On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded Link to comment Share on other sites More sharing options...
