SCV3000D running 3 X-12's?
Only problem is, is that you would be starving them for power. 3 dual 4 ohm subs can only be wired to 2.67 and 6 ohms. You will barely have enough power for 1 sub let alone 3. An scv3k runs 1500 at 2 ohms and you would be just over that, then throw some rise in there and yeah. Somewhere between 1k-1.5k give or take. I was going to be running a very similar setup, 3 x 12's with a same sized alt and 4 xs power xp3k's. Debating on Dual 1 ohms to wire to .67 or Dual 2's to run at 1.34. I think thinking of staying on the safe side since to power them suffieciently I don't think a 280a alt can do 4k-6k watts at below 1 ohm. So I am in the search of an amp or amps to get me at least 5k near 2 ohm.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
And .67 ohms. You forgot to math before you spoke.
Isn't series/parallel the way to get the lowest with dual 4's? Which would be 2.67. I didn't do math, used a website, cry more or be butthurt somewhere else.
Edited by RooTxBeeR
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
No cry, no butthurt here !
Do it OP, if you have enough battery power. You have a good alt, you may need 2 big AGM : one upfront and one in the back, at least.
(That is the amplifier I want to run on my Zcon 15.)
Edited by notorious97200
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a 2.6 ft3  ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
Ive already got a XS power battery and have the Big 4 with 1/0 wire, so I think it can take it.
You should have no problem then running that. Those subs will be begging for more though. How did everyone figure out that .66. I have only ever used 12volt and could never find anything I would understand for formulas to figure out how to do what ever configuration I wanted.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
.66 is parallel coils and subs. a full parallel circuit, not series parallel. You add the reciprocal of each voice coil (1 divided by 4) and then get the reciprocal of the sum. so:
y equals the voice coil resistance, and x is the sum. you have y, so you need to solve for x, and then find the reciprocal of the sum
1/ [x = (1/y + 1/y + 1/y+ 1/y + 1/y+ 1/y)] is equal to 1/ [x = (1.5)] so the reciprocal (1/x) of 1.5 is .66.
That's how you find parallel resistance of a circuit.
now the short easy way for subwoofers since it is assumed that all voice coils of a subwoofer are equal:
you have 3 subwoofers with two coils each, that are four ohm. SO, 2x3=6 coils. 4ohms divided by 6 coils equals .66ohm
I use these websites........... http://www.bcae1.com/spkrmlti.htm
http://www.speakerimpedance.co.uk/?page=calculator
  • Who's Online   0 Members, 0 Anonymous, 837 Guests (See full list)
