Sufkayx Posted November 30, 2016 Report Share Posted November 30, 2016 Hi Im building a subwoofer enclosure for 2 12' type r subs (2kRMS) and wanted to know what size enclosure i should use. I have depth of 17 height of 15 and width of 35 max. I was thinking around 5.5 cubes I want to tune the box to around 32 hertz and want very low bass. What diffrence does a larger enclosure make over a smaller one? Also how big should i have my port i will be using a slot port but wanted to know if a port which its height is less and width is more is better than a port with a larger hight and smaller width. I was thinking a 4' wide and around 9 heigh is thw width fine? All help appreciated Link to comment Share on other sites More sharing options...
ckeeler11 Posted November 30, 2016 Report Share Posted November 30, 2016 given those dimensions you do not have enough room. you will be below 3 cu. after displacements. Link to comment Share on other sites More sharing options...
Parker Grundy Posted November 30, 2016 Report Share Posted November 30, 2016 Looked up the sub and they only displace .1 cubes each. and only want 1.25-1.5 each. I think you should be fine. I wouldn't use this box though, people say it isn't accurate tuning wise, i think. Link to comment Share on other sites More sharing options...
Sufkayx Posted November 30, 2016 Author Report Share Posted November 30, 2016 THanks for the replies. Is there any benifits of having the port width wider than the recomended of 2' to over come port noise i was thinking 4' inches but wanted to know if there is any benifits. Also what are the advantages of using a larger enclosure than smallwe And advantages of using a smaller enclosure Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted November 30, 2016 Report Share Posted November 30, 2016 Larger ported boxes will produce more output around tuning, which usually is desirable, but not always. They also will have higher cone excursion (less mechanical power handling) and higher group delay, which is undesirable. Smaller ported boxes are the opposite. Alpine really undersizes their port area recommendations, you should increase it from what they say. You can make a box that should work with the space you have available, but its a tight fit. Here is an example: "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
