What's everyone using for their air ride connections? I'm about to install an air ride system on my car, and don't know what I need. I've seen some people say use Teflon tape, some say Loctite, and some say pipe dope.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
I've never cared for the pipe dope. Had results with Teflon tape when ALL the threads were nice and clean. I've read about the LocTite method, but I've always been worried that an emergency roadside repair would be that much more annoying with everything glued together.
Locktite makes a Teflon pipe dope in a tube that is the best dope I have ever seen. Tape is ok if you don't get pieces in the fitting that will get stuck in the valve.
Pioneer 80PRS
we use Teflon tape on the ship without any issues. I'm sorry, but if you get pieces in the fitting and stuck in the valve instead of only on the threads, you're doing it wrong.
If you believe the tape will do well, I'm kind of leaning towards it. We have this stuff at work called swak that we use for Swagelok fittings and it would work really well I believe, but I can't get a hold of that anywhere around here.
the Loctite Teflon pipe dope looks pretty good too
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
^I actually think I've seen that in a store in my town
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
You can use teflon tape. Just remember a couple things that make sure you don't get sticky valves.
Teflon tape is a lubricant meant to help bring your fittings together and has an added benifit of sealing a poorly made joint. If you keep the tape a few threads up from the opening of the fitting and wrap the tape correctly you shouldn't have any worries.
People use teflon on cheap pipe fittings they put on the hydraulics all the time and those pumps average 3k psi with some setups going way over that.
  • 3 weeks later...
Tape will work but if you ever take it apart, you have to be able to clean the internal threads so you don't get junk in the valve.
Pioneer 80PRS
  • Who's Online   1 Member, 0 Anonymous, 1034 Guests (See full list)
