SMD Forum: Online Tech Article: The Mechman Advantage - SMD Forum
Latest Vehicles
34191_1339359408908_1378842284_30833996_4272172_n.jpgChevrolet Silverado 2500HD (2008)
Vehicle Owner: smokeumtires
Date Added: 07 August 2010 - 08:52 AM
05.jpgGMC Sierra (2002)
Vehicle Owner: Ray
Date Added: 29 July 2010 - 06:03 PM
Picture 048.jpgchevy astro van (1994)
Vehicle Owner: camaro6991
Date Added: 03 July 2010 - 06:13 PM
2010_07022008Feb0015.JPGMazda 3i Sport (2010)
Vehicle Owner: ptcary
Date Added: 03 July 2010 - 05:08 AM
9932_1239479109117_1293459821_30720699_6402457_n1.jpgChevrolet Silverado Ext. Cab Z71 (2005)
Vehicle Owner: Kryptic
Date Added: 02 July 2010 - 09:25 AM
Share Topic:   del-icio-us digg email facebook google mixx reddit stumbleupon
  • (2 Pages)
  • 1
  • 2
Online Tech Article: The Mechman Advantage How to identify a well built alternator
#1 User is offline   MECHMAN Icon
  • 145db
  • Group: SMD PARTNER
  • Gender:Male
  • Interests:Building high output alternators, big SPL systems, race cars, offroad vehicles, etc...
Posted 18 November 2008 - 01:06 PM
I thought I would start off a series of tech articles to help forum members increase their understanding of alternators, their components, and what to look for when purchasing a high output alternator. The comparison photos below compare MechMan StreetBeat series units to other manufacturers' high output offerings. It doesn't take any special training to see the major difference in construction.
Like any other components in car audio- alternator component beefyness counts. Alternators, like the voicecoil of a Subwoofer, are subjected to MASSIVE amounts of heat, strain and vibration. The heavier duty your components are, and the larger the alternator is, the better it will be able to dissapate heat. Furthermore, the more amperage the alternator produces, the larger the conductors need to be in order to physically transfer current without measurable loss.
The following picture compares two rectifier assymblys. The one on the left came off of a well known brand of High output alternator. Notice the physically smaller anodized blue aluminum rectifier plate. The MechMan unit on the right has a noticably thicker solid lazer cut copper rectifier plate, capable of dissapating much more heat, and conducting more current with less resistance. We all know how much better of a conductor copper is than aluminum. you will also notice a difference in the plastic covering the diode connections. Ours is much higher temperature, and physically larger. It may be hard to see, but the diodes in out rectifiers are much heaver, over .080 larger in diameter; 70 amp rated instead of 30 amp rated.
Posted Image
In another picture, we can see the huge difference in output posts. While it might seem like a simple upgrade, the charge post is responsible for carrying the full output of the alternator, which can easily exceed 300 amps. Running multiple runs of 1/0 cable seem almost pointless when the ouput stud itself is so small. Many car audio competitors have even had their output studs break off simply from the weight of 1/0 cable!! Under dyno testing conditions at full output, I have seen smaller output studs from other companies reach in excess of 400 degrees because they are too small. -NOTE- Larger charge posts are not available on all MechMan alternators. Some units have a samller charge post that is integral to the recitfier plate, and subsequently does not have overheating issues.
Posted Image
Here's another shot of our GM offerings. Our Rectifier is almost twice the thickness of our competitors in this case. The black rectifier on the left is on a popular brand unit that is claimed to produce 380 amps, but only managed to put out a peak of 288 amps on our dyno. :( Our pictured unit on the right is one of our 250 amp rated StreetBeat units, and it actually made 271 amps on the same dyno.
Posted Image
Posted Image
The stator, or fixed windings of the alternator are responsible for determining the output curve of the alternator, and also what created most of the heat in an alternator. If you have ever smoked an alternator, chances are that the smoke was coming from the varnish on the stator windings burning off. This typically occurs around 350 degrees. It is important to know that any alternator stator (including MechMan) will burn if the alternator is abused or run at maximum output for too long. Our stators are built with the highest temperature components and highest grade copper available, but are still suseptable to failure if abused by the customer. This is why it is so important to monitor voltage when playing your system. If batteries are ever run down, the MUST be charged up with a battery charger before the vehicle is started. Also, a vehicle's voltage should never be run down below 13V with the engine running for more than a couple minutes at a time. The system needs to be turned down for a few minutes in order for the alternator to catch up and cool down.
Posted Image
The Rotor is the spinning portion of the alternator. It creates a magnetic field when energized, the when spun inside of the stator windings, causes electrons to flow through the stator, this is how an alternator converts mechanical (spinning) energy into electrical current. The stator on the left is an example of a "re-wound" stator, and a poorly executed one at that. Notice how not all of the rotor is "filled" up with wire, and it is haphazardly wound like a fishing reel. This wastes space, decreases the magnetic field, and subsequently the performance of the rotor, especially at low RPM. Most high output alternator companies don't even bother trying to wind a rotor, and utilize a stock rotor. Improved rotors are very expensive, (especially if done properly) and require other components of the alternator to be upgraded as well. Notice the clean, new windings of the MechMan rotor on the right.
Posted Image
Internal components are just the beggining of what sets MechMan high output alternators apart. Most midsize, compact, and import vehicles come equipped with very small alternator housings from the factory. Auto manufacturers have designed the smallest, lightest alternators possible in an effort to conserve weight and fuel economy. Modern import alternators are very efficient for their size, and cannot be easily improved upon like the simplistic domestic alternators of 20 years ago. The only way to increase the output on most small case alternators results in decreased output at lower RPMS. All other alternator companies rely on this technique because it is cheap and easy. This is why so many people who have bought high output alternators from other companies expierience low voltage or poor performance at idle- Most times they have less low RPM output than a stock alternator!!
MechMan units are built completely differently. We have a full CNC machine shop in house, where we mass produce custom machined LARGE case units that have the same mounting specifications as the factory small case alternator. By going to a physically larger, late model efficient alternator design, we can achieve massive output (250+ amps) while still maintaing brutal idle RPM performacnce. (over 150 amps) In addition, larger internal components can be used which dramatically increases full temperature performance and durability through heat dissapation that can be in excess of a 400% improvement of small case units. The picture below illustrates the dramatic difference between out units, and a competitors "150 amp" offering on the left. With no surprise to us, the brand X unit on the left barely mustered 5 amps at idle, with only 123 amps peak. Our unit on the right made 161 amps at idle with 268 amps at cruising speed- BOTH OF THESE UNITS FIT THE SAME VEHICLE. Notice the 1/0 included copper terminals for Positive and Ground cable connections. The grounding point is pressed directly into the alternator case to give the best possible grounging point. What good is making amperage if you can't get it to the battery??
Posted Image
Posted Image
Again, it doesn't take any special alternator knowledge to know the our unit on the right is going to be able to make WAY more current with much better durability. The tiny components on the unit on the left will simply melt if subjected to daily abuse. (assuming that you rev it up to get any output whatsoever) This is just one example of our 1,200+ large case conversion kits, all of which replace the existing small case alternator with a physically larger unit. This requires a custom machined housing, a plasma cut adapter bracket (in some cases) and an adapter harness that allows the stock alternator wiring to plug right in. Obviouslly, the unit on the right is going to cost more to build, but in many cases will sell for the same price as the high ouptut unit from one of our competitors that is based on a small or medium sized (cheap) alternator housing.
Even on fullsize doestic vehicles, we ONLY use large case units for Street Beat and higher models, because it is the only way the customer will be happy with the way the unit performs. Other companies just sell the unit cheap, and hope that the customer never gets ahold of a DC amp clamp capable of measuring the alternators actual output. Below is an example from a full size ford Truc. In addition to being larger in size, the MechMan unit is actually a late model, more efficient design that will run cooler and last longer. We even include an adapter harness so that the old wiring can be retained.
Posted Image
As you can see, we do things very differently here at MechMan Power systems. Most of the time, our units are priced BELOW the competition, even though our units require much more labor and cost to build. The end result is a far superior product, that actualy goes above and beyond it's advertised benifits.
It is not an issue of our unit working better than our competitors unit, is an issue of the customer recieving a product that accomplishes what it is supposed to.
Here are some shots of our dyno room. This is where every alternator we sell undergoes a fully automated test session that meassures ouput under varying load from 0 to 12,000 rpm rotor speed. We then take the unit up to 16,000 rpm for a couple minutes to make sure that everything seats properly, and any component failures occur and are rectified BEFORE the customer gets the unit.
Our alternator dyno is highly sophisticated, and measures everything from thermal loss, to horsepower input, to individual component temperature. We even have a thermostatically controlled oven the we place over the alternator that simulates hot under-hood conditions for extended durability testing.
The two units pictured here are our signiture StreetBeat Large case GM units equipped with out adjustable voltage feature. This allow the customer to set charging voltage wherever desired. (13.5 to 18.5 volt range) This can be ordered on any of our units with the external adjustable regulator option for only $99 aditional, but is especially convinient on the GM units because it is adjustable on the alternator case itself with no external regulator or wiring required.
For systems utilizing 12 volt AGM batteries, we typicaly set the regulator to 15.2 volts cold, which settles in to about 14.9 volts at full operating temperature. This is the maximum reccomended charging voltage for AGM batteries. Flooded type conventional batteries can be safely charged around 15.3 volts wihtout damaging them. The increased voltage results in higher amplifier efficiency, and a better charge state for the batteries.
The screen demonstrates the full output curve from idle on up to 8,000 rpm rotor speed, and will be printed out and placed in the box with the unit for the customer to review. It is important to remember that the RPM on the dyno displays ROTOR rpm, not engine RPM. Most vehicles have a 3:1 alternator pulley ratio, which means the alternator spins three times faster than the engine. In other words, 800 engine RPM would have the alternator spinning roughly 2,400 rpm. You can easily calculate your exact pulley ratio by dividing the diameter of your crank pulley by the diameter of your alternator pulley. For example: a 6" diameter crankshaft pulley divided by a 2" alternator pulley = 3:1. Most MechMan units are shipped with a 1.75" pulley.
Pics Temporarily removed......Mechman contact me for info - thanks! :)
This post has been edited by meade916: 19 November 2008 - 07:35 PM
You can never have too much power.
0
#2 User is online   Team Sundown's Charles Icon
  • 135db
  • Group: Members
  • Gender:Male
Posted 18 November 2008 - 01:20 PM
wow :friends:
1993 Mazda Mx-3
2010 Setup
Headunit: 7" Touch screen With Nav & 30gb Ipod
Speaker: 2 pr MB Quart ESA216 6.5" COMPONENT
Subs: 2 Sundown 15" Nightshades
Highs amp: Sundown SAX-100.4
Sub amp: Sundown SAZ-3000D
Electrical: Red Top under hood, 2-Kinetik 2400 & 800 in the rear
All 1/0 KnuKonceptz Wire Power/Ground, Big 3, 8Ga Speaker Wire, KnuKonceptz Karma RCA's
Dampening: 120sqft 80Mil Thick Sound Destroyer Mat
Goal: 150 DB 149.9 Street Bass
My Upgrade later For 09
Add another Sundown SAZ-3000D
Add a 1400 under the hood & another 2400 in the rear
Add 200 or bigger amp alternatorA(2 alt setup)
Posted Image
0
#3 User is offline   Torres Icon
  • 175db
  • Group: 18+ All Access!
  • Gender:Male
Posted 18 November 2008 - 02:03 PM
very nice write up. i'm sure it'd make people more confident buying alts from you. i know i would feel more confident
My GUI Box Tuning Calculator Download --- UPDATED!! 3/10
Please download the new version if you use the old one
32 Sundown E8 Build
View PostWorm442, on Dec 5 2008, 12:43 AM, said:
Screws hold down wire and screws on top of screws are to hold the screws below tighter.
~~the light bulb wasnt an invention with 1000 failures...it was an invention with 1000 steps~~
My Feedback
0
#4 User is offline   la negra Icon
  • 125db
  • Group: Members
  • Gender:Male
Posted 18 November 2008 - 02:18 PM
all i can say is some other companys might go out of bizznizz lol
Posted Image
0
#5 User is offline   MECHMAN Icon
  • 145db
  • Gender:Male
Posted 18 November 2008 - 02:28 PM
Also, it is important to remember that for some applications, the beefiest and biggest components are not necessary, especially at lower amperage levels. For light duty offroad vehicles, hot rods, or any large case unit up to about the 200 amp range, standard heavy duty components will live fine in most cases. Car audio however, is one of the most demanding climates for a high output alternator, and it should be built accordingly. The primary purpose of this thread, is to show that not all high output alternators are created equally, and not everyone is as honest as I am regarding rated ouput figures.
0
#6 User is offline   98HOEONSIXEZ Icon
  • 125db
  • Group: Members
  • Gender:Male
Posted 18 November 2008 - 02:41 PM
Do you hand wind your own stators in house or do you just buy them from somebody else?
0
#7 User is offline   MECHMAN Icon
  • 145db
  • Gender:Male
Posted 18 November 2008 - 03:39 PM
Ha ha, wind them in house... No we don't wind them in house, all of the hand wound stators I've seen usually look terrible. We have tried some hand wound samples from various supliers, but they have never performed better than modern production pieces.
We have our components made by a machine-wind capable facility to our specs. They always exceed our performance expectations, plus we always have them on the shelf. (which means faster ship times for our customers) We typically ship all units within 48 hours.
0
#8 User is online   Applejack Icon
  • 160db
  • Gender:Male
Posted 19 November 2008 - 11:28 PM
sweet now i don't have to take mine apart to see how it works! thanks!
Midwest Car Audio is on facebook!
http://www.facebook....101253286585630
0
#9 User is offline   tejcurrent Icon
  • 150db
Posted 20 November 2008 - 04:07 AM
Nice write up. The comparison pics do a good bit of the talking themselves :)
American Bass
XS Power
IA
Team Vertex
0
#10 User is offline   98HOEONSIXEZ Icon
  • 125db
  • Group: Members
  • Gender:Male
Posted 20 November 2008 - 08:39 AM
wow how much does an alternator dyno like that cost you if you dont mind me asking?but i guess its something you have to have right?
0
#11 User is offline   MECHMAN Icon
  • 145db
  • Gender:Male
Posted 20 November 2008 - 08:46 AM
I don't know, how much it cost exactly, but I have heard that it was very expensive. We used to just use Dennis' home-made load-bank style tester, but we can get a lot more data with this tester. It allowed us to see a lot of things we couldn't see before, which really helped out in stepping up the output on our recipies.
0
#12 User is offline   trainman0978 Icon
  • 150db
  • Group: Members
  • Gender:Male
  • Interests:I drive trains in the middle of the night mostly....
Posted 20 November 2008 - 09:36 AM
I am really interested in purchasing a h.o. alternator when the tax refund comes this winter. So far I have only found one source that can build one to fit my vehicle. I have already done business with you, and it was hassle free, so I am curious, what can you do for a 2007 Toyota FJ cruiser with the 4.0 liter V6 ?
We can go to p.m. if you like....
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
View Post00sdime00, on Sep 6 2009, 05:36 PM, said:
Shoehorn, BFH, forklift,duct tape and some zip ties
0
#13 User is offline   MECHMAN Icon
  • 145db
  • Gender:Male
Posted 21 November 2008 - 09:00 AM
To my knowledge, we are the only company that has developed a true bolt-in Large case conversion for the FJ. There is actually one of out units currently installed on the Pioneer Demo FJ that was at SEMA. It is $499, and is rated at 250 amps with 150 at idle, although it typically does better than that on the Dyno. It is a good bit larger than the stock Hairpin piece, so it is still nice and durable.
This post has been edited by MECHMAN: 21 November 2008 - 09:00 AM
0
#14 User is offline   RamenNoodles Icon
  • Oriental Flavored
  • Gender:Male
Posted 21 November 2008 - 09:15 AM
380 amps. Hmmm maybe an Iraggi by chance :) Looks kinda like one.
Damn nice write up though, I look forward to many more and reading them all.
Do you have any alternators for a 2000 accord 4cl 2.3L ULEV VTEC?
0
#15 User is offline   littleitaly1990 Icon
  • Godfather of Bass
Posted 21 November 2008 - 09:17 AM
Just for how simply you wrote that up and how deep and informative it was, I promise I will purchase my next H.O. alt from you, they look sick as hell.
A vitrolic, megalomaniacal sadistic psychopath.
0
#16 User is offline   MECHMAN Icon
  • 145db
  • Gender:Male
Posted 21 November 2008 - 02:44 PM
Yup, we have our new 150 amp large case conversion kits (honest 90 amps at idle) for $349, and the full-on StreetBeat large case conversion for $499. Both are a direct bolt in, and will be a large case 100% new alternator, not an overwound little honda unit.
0
#17 User is online   E a r t h Icon
  • 160db
  • Group: SMD Silver Member
  • Gender:Male
  • Interests:Bass makes me happy-er
Posted 26 November 2008 - 02:13 PM
This deserves a sticky :D
Posted ImagePosted ImagePosted Image
Posted Image
0
#18 User is offline   CUT BUDDY Icon
  • 130db
  • Group: Members
Posted 01 December 2008 - 08:14 PM
so basically what your saying is even the regular internally regulated streetbeat alts ( with out the $99 regulator) come set @ 15.2V?
Posted Image
TEAM MechMan Alternators
0
#19 User is offline   wildbeast15 Icon
  • 150db
  • Group: SMD Gold Member
  • Gender:Male
  • Interests:Girls cars and sound
Posted 01 December 2008 - 08:19 PM
sorry but are your alts true amps.... a local shop took a irragi alt and spun it at nascar speeds and could not match the amperage that irragi said it will pump out(300) it only could do 190... so we tried it again with diffrent alts and same result..
Basicly im asking are they all true power alts???
Posted Image
Posted Image
View PostTahoeJoe, on Nov 12 2009, 09:47 AM, said:
The set up your talking about would sound great in my Tahoe. Trade you my dog for it. He has one eye but that only makes for bad depth perception so hey so what if he is running into shit, look at it this way he is easy to sneak up ninja style on. (right side only)
</div>
0
#20 User is offline   MECHMAN Icon
  • 145db
  • Gender:Male
Posted 02 December 2008 - 11:07 AM
They only come set at 15.2 V if they are ordered with the internal adjustable regulator. This option is only available on the GM applications.
All other internally regulated StreetBeat units are pre-set at 14.7V cold.
0
  • (2 Pages)
  • 1
  • 2
Fast Reply
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
LaFountain Design | Professional Web Development
