well today after driving around for awhile i got something to eat and went out again driving to my local pullapart and on the way the amp went out... just stopped working... it blew the main fuse only 80amp, so i checked out the amplifier wire to check for a short or loose wire but it all checked out fine. hooked up my light tester to charge the amplifier before putting in a new fuse. goes in just fine, then go inside the car and start it up to listen to the bass again and instantly pop the fuse blew again only 60amp since thats all i had right now.
and ive never had a fuse blow before on this amplifier! and even the fuse on the amplifier itself is original and still not blown.
so since i had used all of my agu fuses i hooked up a new 200amp circuit breaker that i bought for my truck hooked it all up everything just fine, then i turn the car on and it makes this god awful whining. so i turned it off unplugged the rca wires and it still gave the awful whining noise and then smoke started coming off the amplifier so i jumped as fast as i could to turn off the ignition and kill the power on the circuit breaker.
luckily it didnt damage my subwoofer since its still a good 4ohms.
IT IS A T10001BD
ive had it since about June 6, 2007 so im positive no warranty since i bought it off ebay.
i have really liked this amplifier ever since i had it!
so ill either be buying another or send this one out for repair if the repair cost will be cheaper than a new one.
and i was about ready to put the amplifier in my truck to.
its been hooked up to a alpine type R 15 dual2 ohms wired at 4ohms so was only pullen about 600-700watts for the sub. well under what it can do.
this just really REALLY SUCKS!!!!!!! i havent had a good amplifier blow in about 10years now. just when im very short on cash this happens
This post has been edited by addiction2bass: 12 April 2009 - 01:29 PM
Sign In
Register
Help
Add Reply
MultiQuote
