Posted 13 April 2009 - 04:47 PM
Yes they are strappable.
I deal with the 2003 1501BDs and called them about this question incase I had problems getting as many 2003 1501BDs that I wanted and they said there shouldn't be any issues if I needed to use a 2001 BD1500.1 or a 2002 15001BD.
You should be good to go.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
A cap is only good if you have 0 voltage loss and want to clean up the power at the peaks of the ripples..
Boon: Don't get hung up on specs like xmax. It's probably the third-most lied about spec, after power handling and sensitivity.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
was the fact I won't get to find out whats going to happen tomorrow if I die today.
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Hoo-Bangin' on the transformers
Getting my stalk on walk on
"Skip skip"
Sack jacking purse snatching hoo-banging till I die
