Wow...am i reading this correctly...slightly above 1 ohm, at 12.8 volts the 1500 made 1900 watts? Holy sh!t..so wouldnt this thing easily break 2k on a solid 14+ v system. Damn that is insane.
Assuming the same ohm load, you could easily break 2kW with a solid 14+ volts.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
  • 3 months later...
Very UNDERATED.. I have had the opertunity to played with a SAZ3000 and now a SAZ35000 and I will say VERY UNDERRATED.
Customer for life here......
I am looking at getting another 3500 come the turn of the year to run a bunch of SA12's.....Fun times for sure...
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
  • 4 weeks later...
  • 1 month later...
SAE-1200D:
POWER : 1770 Watts
AMP VOLTAGE (measured) : DID NOT MEASURE
AMP CURRENT (calculated) : DID NOT MEASURE
ACTUAL IMPEDANCE (calculated) : DID NOT MEASURE
SUPPLY VOLTAGE : 12.65 V
What will this amp do at 14.4 Volts?
Close to 2000 Watts?
  • Who's Online   1 Member, 0 Anonymous, 271 Guests (See full list)
