2000 Monte Carlo Factory Amped Raido Wire colors
Hotdog
I am trying to hook my son up with some bass but this 2000 Chevy Monte Carlo has a factory amped system.
I went to The Twelvevolt dot com and got the wiring information for it but it does not match.
The speaker wire colors are correct but the other wires are as follows
12volt said
Constant 12v+ = Orange
Switched 12v+ = Yellow
Ground = Black/White
Illumination = Grey/Black
Dimmer = Brown/White
Antenna = Glass
What I actually have
2 black wires
2 orange wires
Purple wire
White Wire
Grey Wire
Pink Wire
So can anyone help me here?
The goal it to wire in a line level out and run RCA's to another amp for some subwoofers.
2 12" Rockford Fosgate Punch XLC
Rockford Fosgate P600/2 for amp
Can anyone help here?
I think I found where the White wire is the remote wire but I am unsure on the 2 black wires unless they are both grounds. I guess I can take a picture of it
If you're wiring in a LOC then all you need to worry about is the speaker wire color for the rear speakers, right? That's all I did when I installed my first setup in my car w/stock head unit. I just tapped into the rear speaker wires with my LOC, which gave me my rca's, remote lead was run from the fuse box, power lead from the battery and that's it.
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
I got it now
The White wire on the radio harness is the antenna/Remote wire.
Now all I have to do is replace factory speakers later on... my son should be happy with it now.
I got it now
Make sure you get 2ohm speakers if you're going to keep running the factory amp
The factory amp is still being used and the factory speakers in the rear are 4ohm
really? When I took out my factory speakers they were 2 ohm
Posted Image
Maybe they changed them between 2000 and 2004???
