new box plans
scfaust
According to Torres calculator and the measurements given and 3/4 timber with single layer all round I get:
6.62cu ft after disp 72.5" of port tuned to about 34.3 hz.
Port area would be a little low for the size of the box still.
If the port was made to 6" wide and the section of port on the back wall increased to 7.75" long will keep a low tune and net much more port area 87" to be exact and the box volume comes down to 6.05cu ft.
What power will be runnning into the drivers at what load. The smaller volume and bigger port may or may not be a good thing.
Systems:
Fun Car:
Deck: Alpine CDA-9887
Front sounds: Alpine SPR-175A x2
Front power: RF T400.2 Benched at 265x2 rms @ 2ohm
Subs: RF T1 10 dual 4 Ohm x1
Sub power: RF R500.1
Box yet to be built.
All in a Mazda 323 Hatch in the cargo area only.
Daily hack:
Deck: Alpine CDA-9886
Front sounds: RF T152 5.25" coax x2
Front power: RF Power T400.2
Subs: Alpine SWR-1021d x4
Sub power: RF Power T20001
4.59cuft net 56" of port tuned to 32hz.
Work ute
Deck: Alpine iDA-X303
Speakers front: Stock
Speakers rear: None
Subs: Alpine type S SWS-1040
Amp: Alpine MRV-T320 x1 for woofer.
Box 1.42 cuft 39hz hidden under tray in blow thru design.
New ute to be much different.
what if i used 1 inch thick wood
If the original plans were made with 3/4" stepping up to 1" will require re-working the design a little as the sheet sizes will be different. Are they to max dimensions that you can use or a design supplied with a woofer? even in 1" going with the external dimensions of the original plan will net a smaller box and different tuning.
Systems:
Fun Car:
Daily hack:
Work ute
Speakers rear: None
  • Who's Online   0 Members, 0 Anonymous, 1065 Guests (See full list)
