just wondering if a circuit breaker such as
http://cgi.ebay.ca/250A-250-Amp-Manual-Reset-Circuit-Breaker-XScorpion-12v-/290447795958?pt=LH_DefaultDomain_0&hash=item43a009a6f6
would work as well as a 250 amp fuse? would there be more resistance or would it work fine.
i'd rather flip a switch if i pop a fuse, than going threw the motions of switching fuses. thanks for the help.
I'd go with fuse and buy a lot of extras, put your fuse where it's easily accessible... I have no idea if it's good or bad, but I've not seen anyone use a circuit breaker on this thread, but I have at a car show.
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
The problem with circuit breakers is that they wear out over time, and the connection gets worse. They also take more time to blow (or "open") than a regular fuse/ The point is that fuses shouldnt be blowing anyways unless you are doing something wrong, so if you are doing things right you shouldnt have to worry about changing them anyways.
My vote goes to the fuse B)
Eclipse cd7000
thanks guy's i'll just go with fuses. i know i shouldn't pop fuses but it happens sometimes. connection get's loose or w/e. but fuses it is thanks again guy's.
thanks for the info on breakers fink
Edited by Reaper
^^ This... I have never blown a fuse ever... I have extras but they just sit around lol...
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Couldn't of said it better :good:
Fuses all the way... Breakers are only good for their rating for a few times, then they start becoming weaker and weaker with each trip
1999 Chevy S102 Sundown Zv3-10's1 Sundown saz-4500d2 sets of Sundown CS6.5 Comps. (Doors)
2 10" Sundown NeoPro 10's (Doors)1/0 KnuKonceptz - Power x2- Ground- Big 3
300 Amp External Regulated Excessive Amperage Alt
147.8 Sealed Mic on Windshiled148 30sec. Average Drivers Door open Mic on Windshield
Check Out my YouTube Channel --->>> http://www.youtube.com/user/dmntyo2007?feature=guidehttp://www.stevemead...ld-competition/
breakers also cause fires some times
R.I.P!
(Nov-29-2009)
92 explorer
current build
