XS Power
Welcome to SMD Forum
battery isolators, do I need one??
20 replies to this topic
#1
Davo2378
Davo2378
    120db
  • Members
  • 33 posts
Ok so I have a brand new 3 month old Everstart Maxx 75N up front and I'm going to put two XS D1200 in the back.
My question is do I need a battery isolator?
And my other question is do I hook my 1/0 wire to the front battery or to the alternator?
#2
UnderLoK
UnderLoK
    155db
  • 18+ All Access!
  • 2,034 posts
  • Gender:Male
  • Interests:Classic boats, cars, computers, and the list goes on...
No isolator needed. You run 1/0 from your alt to your front batt and then from that front batt to the rear batts.
Edited by UnderLoK, 28 December 2010 - 11:55 AM.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my 18'ish kw walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a Soundstream STL 4.500
Pioneer X8500
6 XS Power D7200
Second Skin
2 270a Mechman Alts
#3
Davo2378
Davo2378
    120db
  • Members
  • 33 posts
to the rear from the front battery NOT the alternator
#4
Davo2378
Davo2378
    120db
  • Members
  • 33 posts
ok I got it, and I already have the big 3 done so I just need to run the 1/0 to the back from the front battery.
But your sure I dont need an isolator
#5
FaTbOy911
FaTbOy911
    130db
  • Members
  • 465 posts
  • Gender:Male
  • Location:Born and Raised in East LA now living in Guatemala
  • Interests:Car Audio,Gameing and eating peanuts
Ok the isolator in my opinio no. About the 0gauge do the big 3 wich is 0 from battery to alternator and upgrading ur negatives to be specific it explains it better in the electrical section and use 0gaugd from the front to the back batteries
Posted Image
Posted Image
Had an estimate of 6400 for an alpine/clarion setup dealer said it "should" hit around 160db with the custom boxes he was going to make for me..doubtful with so much area to move but, budget is way below that :( any ideas on cheaper brands for that kind of Spl setup? really didnt want to try any Boss or soundstorm, thinking Quantum figure around $150 per speaker "$1800 total" and $1700 to power it, first actual big setup for the van.
New MEMPHIS CAR AUDIO build
4 15s Memphis C3
2 xs power D3100
1 xs power d3400
custom fiberglass door pannel
and lots more
My Build
#6
Davo2378
Davo2378
    120db
  • Members
  • 33 posts
ok thanks, UnderLoK and FaTbOy911
#7
NRG
NRG
    125db
  • Members
  • 172 posts
  • Gender:Male
No isolator needed unless you plan on playin music without the engine running for extended periods of time (not recomended)
#8
audiofanaticz
audiofanaticz
    Adjust the bass and let the /////Alpine blast!
  • Super Moderator
  • 8,388,607 posts
  • Gender:Male
Fact: Battery Isolaters are only needed when you plan to play your system of a separate battery with the vehicle off. The Isolater then wont allow the stereo to drain which ever battery is being isolated so the vehicle can still be started.
#9
Davo2378
Davo2378
    120db
  • Members
  • 33 posts
Oh ok that helps out alot thanks you guys
#10
FaTbOy911
FaTbOy911
    130db
  • Members
  • 465 posts
  • Gender:Male
Np glad i can help
Posted Image
Posted Image
4 15s Memphis C3
2 xs power D3100
1 xs power d3400
and lots more
My Build
#11
dereileak
dereileak
    145db
  • UBL Approved Group
  • 1,361 posts
  • Gender:Male
  • Interests:Car Audio, Computers, Fun
I was wondering if I could get a reply from nathan. I have a D3100 in the back and a d3400 in the front. I have read that having different size batteries can shorten the life of them, because when you turn off the car they can try and take current from each other to equalize. I was was just wondering if it would be recommended to isolate them, I have read the post above and from what I can see I do not, but I just want to make sure that this is 100% as i don't want 500 dollar in batteries to go down the drain, lol, within a couple years. I have a 130 stock alternator now, I was looking at a mechman 340 amp one possibly in the future, but I don't think I want this van forever, and it would be hard to sell that alternator afterwards, ha ha
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
#12
Nathan @ XSpower
Nathan @ XSpower
    150db
  • Members
  • 1,568 posts
  • Gender:Male
I do not recommend isolators in any car audio install, unless you are going to be running the system with the vehicle off and just pulling from the battery bank. Even then it is not necessary. Is it going to hurt running one...... No not really. You will drop a little voltage going through the isolator and it will cost some $$$, but if that is ok with you then run one.
As far as your application it will not hurt the batteries at all to not use an isolator. Different sizes of the same batteries doesn't matter and will not hurt the batteries. There are many installs where you can only get a D1200 under the hood, but you can load up the D3100 in the back. It will not hurt the D1200 to do it like that.
Posted Image
Reply to this topic
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
