drigo210 Posted February 23, 2011 Report Share Posted February 23, 2011 So i just got my new Tahoe and i was going to install my system in it but i have a question. I got a 0 Gauge wire and i was wondering if i could run it under the truck instead through inside? and if you can what would be the best route. Quote Link to comment Share on other sites More sharing options...
Trâgîk Posted February 23, 2011 Report Share Posted February 23, 2011 People do it but you need to run it in some conduit. Its not the best thing to do but if you have no other choice you can. Alotta people here have that vehicle so im sure they can give u the best route Quote -----SELLING EVERYTHING---- 2 DC sound labs 3.5k's (still avail) 2 HDC312A D1's (still avail) 5 XS Power Batteries (1 d3400 and 1 d1200 left) 4 runs of knukoncepz 0 gauge (have all the wire still) DC power 270XP alt (sold) RF T1 6.5 components (both sold) Powerbass XAX 4160 (still avail) Custom built box 4.75^3 tuned 34hz (still avail) Link to comment Share on other sites More sharing options...
drigo210 Posted February 23, 2011 Author Report Share Posted February 23, 2011 Hmmm alright i hope i canget the answer Quote Link to comment Share on other sites More sharing options...
Superjay Posted February 23, 2011 Report Share Posted February 23, 2011 I almost always run large wire under the Tahoe...Very rare that I don't. Waterproof conduit is the best choice for you, but if you wrap it in techflex and/or split loom and secure the cable as high as possible next to a frame rail (away from gas lines) you should be fine. Quote Principal JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it Link to comment Share on other sites More sharing options...
drigo210 Posted February 23, 2011 Author Report Share Posted February 23, 2011 jay you think you can take some pictures or do you have a build log so i can see how yours is? Quote Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted February 23, 2011 Report Share Posted February 23, 2011 i did. i dont have anything covering the outside of it but it is also like 18inches or more from the ground and ran above the frame and almost completely shielded from the ground. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
drigo210 Posted February 23, 2011 Author Report Share Posted February 23, 2011 where did you run it?? like what part of the frame or where Quote Link to comment Share on other sites More sharing options...
Superjay Posted February 23, 2011 Report Share Posted February 23, 2011 I don't have one...I've done hundreds of them though. I haven't been in the bay for about 6 years. Run the cable straight down from the main harness to the frame rail. Secure the cable with screw secure zip ties every 6 inches. ANY droop in the cable will grow over time, so make sure it's pretty tight. Run the cable back up through the rear tub...do not run it straight in or water will follow the cable into the cabin. secure the hole with a waterproof grommet (screw and lock 2 or 3 piece type) Quote Principal JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it Link to comment Share on other sites More sharing options...
white4d96 Posted February 23, 2011 Report Share Posted February 23, 2011 I think I remember seeing people use PVC pipe as conduit before. Quote Too many projects, too little time... Link to comment Share on other sites More sharing options...
Superjay Posted February 23, 2011 Report Share Posted February 23, 2011 I think I remember seeing people use PVC pipe as conduit before. This works, also. bend it up against the body to the engine bay, but drill a hole at the bottom of the bend so water can drain...otherwise you'll end up with a pipe full of water Quote Principal JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it Link to comment Share on other sites More sharing options...
