Does cone aera have anything to do with SQ?
O geez SQ is NOT and i repeat NOT meant to be loud at all. I would never use an 18" in a SQ setup. I would run maybe two 10"s sealed but thats it. Your mids and high are supposed to blend very "smoothly" which mean bass isn't louder then mids and highs and vice versa.
I put a Peavey Low Rider 18" in my buddy's escort and it sounded like GOD!
well personally i'd rather run smaller subs and maybe 1-2 more in sealed enclosure. I can get a good flat response with the subs and I like the double beats with smaller subs on lower power levels.
Johns.jpgSuburban Coming Soon
My first massive cone area setup is my home theater. With 8 18" subs, I can tell you there can be incredible SQ with large subs and a lot of cone area. . .minimizing excursion can definitely add to the overall SQ.
Current system:
Previous systems:
I'm going to disagree.
Cone area really has nothing to do with SQ to a certain extent.
That's like saying you can only uses 6.5 inch mids.
you say you disagree then agree..
And Bkolf04 aren't those subs in a IB setup? Thats a whole different cenario.
That kinda my idea behind building a good sounding system... Have tons more cone area and power than you need and back it down... Just b/c the subs have 3" of throw doesn't mean you need to use it... Lowering the excursion of the woofer makes it much more responsive.
To get my truck to blend and pay flat... My highs may be full tilt but my sub control is all the way down and it blends perfect... The sub only sees maybe 1/4" of excursion tops.
Edited by wL<3bass
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
There are, and have been, many SQ guys using 15" and 18" subs. This is mainly due to the fact that with a larger cone you need less excursion for a given loudness, thus reducing distortion.
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
Answer to your openingspost and your latest question: Nothing!
You can use the biggest, brutal subwoofer and still use it for SQ!
It all depends on the box!
Just create a lineair responsing box. (the flat sound stage wich was refered to)
And use Real-Time-Analising (RTA) measurment to connect it to the kicks/mids en highs of your system.
______Some people and performances are beyond words______
Chairman of the foundation "Propper-Droppers Holland" 2012
Founder of the European delegation of `Propper-Droppers' 2011
Dutch Champion EMMA SQ MultiMedia advanced 2010
European Champion EMMA SQ experienced 5 channel 2007
Dutch Champion EMMA SQ experienced 5 channel 2007
BeNeLux vice Champion dB-drag street-A 2007
Dutch vice Champion dB-drag ministreet-sedan 2004
_________________________________________
Propper Droppers is about deep, ground wobbling, elephant-and-whale stimulating Street Bass.
The deep stuff. We test at different frequencies from deep, to low to snake’s belly. (Like 20Hz anyone?)
  • Who's Online   0 Members, 0 Anonymous, 1198 Guests (See full list)
