can amps run above 2 ohms when strapped?(like 4 ohms)
Didn't want to start a new thread so I'll ask it here. Is there a diagram on how to wire 2 dual 2 subs to 2 strapped amps? One for a 2 ohm load, and 1 for an 8 ohm load.
do you know how to wire strapped amps?
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Yes, I just double check everything sO nothing goes boom.
when strapping most amps you wire them to a 2 ohm load and it will break that up to a 1 ohm load per amp
so if you went to a 4 ohm load each amp will see 2 ohms
and so on... for most amps
but amps like stetsom you would wire down and have the amps imp raise
so if you wired at 1 ohm each amp would see 2 ohms
R.I.P!
(Nov-29-2009)
92 explorer
current build
All amps have amp rise not just stetsom
True...you just wont notice it/ worry about it as much on some amps though *cough* Rockford Constant Power *cough*
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
  • Who's Online   1 Member, 0 Anonymous, 1238 Guests (See full list)
