How long do your router bits last?
I have all Freud carbide bits and they just are not lasting long with MDF and are already dull and burning the wood after I've cut out about a dozen holes. Is this normal or are there stronger bits I can use?
Edited by bumonskateboard6
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
could also be your forcing the router to much and its burning itself up
R.I.P!
(Nov-29-2009)
92 explorer
current build
I dont know about the longevity. I know my upcut bit has cut its fair share of holes and still cuts like a hot knife. The good thing here is you have carbide tips...they can be resharpened. Find a local guy that sharpens shit and you can probably get it done fairly cheap.
d(-__-)b
I'm using a porter cable 892 router, and it's a 1/4" bit and I'm using the 1/4" shank and running around 16-17,000 RPMs.
I know I can get them re-sharpened I'm just seeing if there's anything I can do to extend their life.
Also where it started burning I was forcing it a little and that probably didn't help any..
Current Systems:
2011 BMW 335i
Hertz HDP1
2002 Acura Tl
Kenwood DNX9980HD
DC 3.5k
Hertz HDP4 Amp
let the router do all the work
R.I.P!
(Nov-29-2009)
92 explorer
current build
Are you getting any build up on the bits? Might give them a good cleaning and see if that helps.
How deep are you cutting in a single pass? Might just be taking too much out at once.
Out of all of the Freud bits, I've had the best luck with their 1/4" straight bit with 1/2" shank.
I've sense switched from Freud to CMT's spiral upcut and downcut (depending on the application) and have had better luck all around with their bits. The spiral bits expel the chips better, seem to last longer, and are fairly inexpensive.
Later,
Have a question about Second Skin? E-Mail me!
Really depends on the bit, the material and the force.
I would try slowing down not only the speed on the bit, but I would also put very little force on it as you work. Seams to work pretty well for me.
  • Who's Online   0 Members, 0 Anonymous, 270 Guests (See full list)
