Torres box calculator
eric78702
I had that problem once when i was building a box for my friend that was ported on the side. Its hard because with RE you cant change which side has the port.
I just messed with the numbers until the port was on the side I wanted.
Didnt take to lond to figure out.
Bottom line is any of the calculators work and give you the right numbers. It's just which one YOU like better.
Big 3 with Yellow Top
Well the RE calc doesn't account for displacement, bracing, etc.....with Torres my tuning says 38hz, with RE my tuning said 35hz. :shrug:
Ok you may have caught me there. :ehh:
i'm not quite sure how mine isn't easy to use? you input dimensions, and it outputs results. you just type in width, height, and length of the box/port and you got yourself a basic box. directions are in the help buttons, and even has links to pictures that show what certain boxes/ports look like. dno what else to say to help you lol
EDIT: and if the RE calc does take out port displacement (which i hope it would do at least that), i bet it doesn't take out end correction
its because your calc doesnt show what the box will look like
R.I.P!
(Nov-29-2009)
92 explorer
current build
It doesn't I would like a visual to see where my port is...
You can put it wherever you want. Just visualize it, sketch it out, and cut pieces accordingly.
