Product: Digital Design M4A
Manufactured by:Digital Design
Purchased/recieved from: Official Digital Design Dealer
--> These amps are beast as they register in at 27 inches in length and weigh in at 36 lbs. Recently installed two DD M4A's and the sound quality is on par with the Rockford Fosgate T4000s owned previously. Low pass filters work flawlesly and the Master/Slave feature on these amps make wiring multiple amps easy.
These amps put out a ton of CLEAN power, you will not be disappointed. Only negative might be the price. Hands down the best amps I have ever owned!
Specifications
Input Sensitivity 0.3v - 5v
Variable Subsonic Filter 10Hz - 50Hz @ 24dB/Oct
Variable Low Pass Filter 20Hz - 200Hz @ 24dB/Oct
Tested Voltage 11.9 VDC
Signal to Noise >100dB
Cont Power at 1 ohm 5200W x 1ch
Dynamic Power 9500w
Dimensions - mm 702L x 232W x 63.5H
Dimensions - inches 27.625L x 9.13W x 2.5H
Shipping Weight 36 lbs
All information is available on the DD website = http://www.ddaudio.com/
Official Scores at the Dash. and YES. My Bass Boxing is louder than Burp! - 155.5 DB Drag Burp- 155.6 - IASCA Bass Boxing on music (30 seconds straight) sealed up Builds 1. The Acura Integra build = http://www.stevemead...s/page__st__6802. BLK SIN Build = http://www.stevemead...w-pics-10-6-07/
  • 4 weeks later...
Ran multiple runs of bassrace, demos, and bass boxing at yesterday's show. Amps were perfect, zero problems. A++
when there are issues, id like to see how they handle it. As im looking at some DD amps at the moment but warranty work scares the crap out of me. Ive never blown an amp but going to DD would be a step down from the amps i currently own so im skeptical.
lol step down? from massives? or a sq amp you have? ive been running my m4s at .35 for a year zero problems
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Yup I don't see myself changing amps for while...I run two m3a daily at 1.4 strapped..there good looking amps good power reliable and fit excatly were I want them..its about power and size for me they fit the bill.good job DD.
  • Who's Online   0 Members, 0 Anonymous, 1397 Guests (See full list)
