Louisiana Bass Posted July 19, 2011 Report Share Posted July 19, 2011 They are not running at 2 ohms then, if using only 1 amp... Quote N8. No homo...unless you want there to be. Link to comment Share on other sites More sharing options...
Katt Posted July 19, 2011 Report Share Posted July 19, 2011 They are not running at 2 ohms then, if using only 1 amp... But say he's only running 2 of the 4 coils, getting a 2 ohm load. That's the only way i could think of. But then again.. i'm not too sure. Quote *06 330i - Sundern x12 - saz-3500* *91 Foxbody V1 S-Trim Notch* Link to comment Share on other sites More sharing options...
bassfiend316 Posted July 19, 2011 Report Share Posted July 19, 2011 They are not running at 2 ohms then, if using only 1 amp... But say he's only running 2 of the 4 coils, getting a 2 ohm load. That's the only way i could think of. But then again.. i'm not too sure. If that's the case, then those subs won't last very long. Lol. Simple answer-Just run all 4 positives together and all 4 negatives together. You will have a 1 ohm load, and will get the most out of your amp/subs. Quote Link to comment Share on other sites More sharing options...
Diamond500 Posted July 19, 2011 Author Report Share Posted July 19, 2011 They are not running at 2 ohms then, if using only 1 amp... But say he's only running 2 of the 4 coils, getting a 2 ohm load. That's the only way i could think of. But then again.. i'm not too sure. If that's the case, then those subs won't last very long. Lol. Simple answer-Just run all 4 positives together and all 4 negatives together. You will have a 1 ohm load, and will get the most out of your amp/subs. The link posted above sounds a little different from what you are saying would this be the right way then or no there is a different way. Quote Link to comment Share on other sites More sharing options...
Katt Posted July 19, 2011 Report Share Posted July 19, 2011 (edited) They are not running at 2 ohms then, if using only 1 amp... But say he's only running 2 of the 4 coils, getting a 2 ohm load. That's the only way i could think of. But then again.. i'm not too sure. If that's the case, then those subs won't last very long. Lol. Simple answer-Just run all 4 positives together and all 4 negatives together. You will have a 1 ohm load, and will get the most out of your amp/subs. The link posted above sounds a little different from what you are saying would this be the right way then or no there is a different way. Yeah, You should be fine. Just wire it that way and you will have a final load of 1 ohm going into the amp. And the reason why you said it looked different, Is because it shows you, you can wire it to 1 ohm or 4 ohm. But you want to wire it to 1 ohm, and that's what you posted so you will be fine. Edited July 19, 2011 by Katt Quote *06 330i - Sundern x12 - saz-3500* *91 Foxbody V1 S-Trim Notch* Link to comment Share on other sites More sharing options...
Diamond500 Posted July 19, 2011 Author Report Share Posted July 19, 2011 Alright Thanks Guys and Thanks Katt. Quote Link to comment Share on other sites More sharing options...
Katt Posted July 19, 2011 Report Share Posted July 19, 2011 Alright Thanks Guys and Thanks Katt. No problem, It's always better to ask and make sure then something go horrible wrong. Quote *06 330i - Sundern x12 - saz-3500* *91 Foxbody V1 S-Trim Notch* Link to comment Share on other sites More sharing options...
