bass_stalker Posted August 4, 2011 Report Share Posted August 4, 2011 my first question is why would i have a scraping noise coming from the rear end of the truck almost as if the brake pads were metal on metal. but they arent. also sometimes my back brakes get stuck. like if im stopped at a red light, when i go to take off the engine will rev but the truck wont go for a second as if the brakes were stuck. could the calipers possibly be bad. also would it be a good idea to flush all of the brake fluid since its probably the original fluid. my other question is what are the easiest modifications to do to the truck. i know of a cold air intake and dual exhaust i also know about getting a tuner. but what else is there that can be done. Quote JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow. Link to comment Share on other sites More sharing options...
korey_hofer Posted August 4, 2011 Report Share Posted August 4, 2011 easiest mod is tbar crank if 4wd and any weird scraping marks in the back? if not it's probably inside the rear axle. Quote previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street. Link to comment Share on other sites More sharing options...
bass_stalker Posted August 4, 2011 Author Report Share Posted August 4, 2011 i never popped off the tires and looked but i felt the brake disks on both sides and they dont have any grooves on them. when i rotate the tires this weekend ill look at every thing a little closer Quote JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow. Link to comment Share on other sites More sharing options...
korey_hofer Posted August 4, 2011 Report Share Posted August 4, 2011 how do you know the pads aren't shot then? Quote previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street. Link to comment Share on other sites More sharing options...
bass_stalker Posted August 4, 2011 Author Report Share Posted August 4, 2011 how do you know the pads aren't shot then? its only been about 3000ish miles since the pads were replaced so they should still be good Quote JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow. Link to comment Share on other sites More sharing options...
1997chevy Posted August 10, 2011 Report Share Posted August 10, 2011 are you noticing any like vibrations coming from the back end Quote The noise of 7000 hp that makes every grease head smile the roar of a top fuel nitro engine Link to comment Share on other sites More sharing options...
badasschevy Posted August 14, 2011 Report Share Posted August 14, 2011 check the parking brake shoes,and make sure the parking brake is adjusted right. sounds like its dragging. Quote center console: lvl 4 12 1.75 cu ft tuned 37htz alpine cda-9886 dc audio 120.4 infinity kappa 6.5" components Link to comment Share on other sites More sharing options...
Bills Posted August 18, 2011 Report Share Posted August 18, 2011 check your brake dust guards, I had a place do some work and they got bent in and rubbed against my rotors, simply just bend them back so they aren't touching, couldn't say that's it, but i'd just check it out. Bills Quote KwB Team DC Audio Midwest captain Link to comment Share on other sites More sharing options...
