Chris661 Posted October 7, 2011 Report Share Posted October 7, 2011 ok guys im a little confused here the question, if i wire a dual 1ohm subwoofer, to a mono amp. example( one coil to side (A)on the amp and the other coil to side ( on the amp, is the amp going to see 1ohm or .5ohm????? i know in parallel it a .5ohm and in series it 2ohms, so im guess if i wire each coil to (A) and ( on the amp it going to see 1ohm correct??? thanks -Chris Quote http://www.youtube.com/user/EAZYCHRIS?feature=mhee Link to comment Share on other sites More sharing options...
**Hollywood** Posted October 7, 2011 Report Share Posted October 7, 2011 A dual 1 ohm wired + wire to + wire -wire to -wire it will be .5ohm Quote Link to comment Share on other sites More sharing options...
Kranny Posted October 7, 2011 Report Share Posted October 7, 2011 monoblocks have 2 sets of speaker terminals solely for the purpose of making wiring multiple subs easier. doesn't matter if you choose the outside + and - or the inside + and -, itll be the exact same. Quote Link to comment Share on other sites More sharing options...
little-kid-wit-bass Posted October 7, 2011 Report Share Posted October 7, 2011 On the amp, or on the sub. It will .5 ohms Quote I cant afford anything... forum.realmofexcursion.com/members/little-kid-wit-bass.html Youngest active user on ROE Link to comment Share on other sites More sharing options...
Chris661 Posted October 7, 2011 Author Report Share Posted October 7, 2011 so either way if each side of the coil is 1ohm, and i run a wire from one coil to the amp(A) and the other coil to the amp( is the amp going to see 1ohm? only one subwoofer. basicly this my question subwoofer coil(A) + and - to amp (A) subwoofer coil( + and - ( amp going to see 1ohm correct? Quote http://www.youtube.com/user/EAZYCHRIS?feature=mhee Link to comment Share on other sites More sharing options...
little-kid-wit-bass Posted October 7, 2011 Report Share Posted October 7, 2011 No. It will see .5 ohms. Quote I cant afford anything... forum.realmofexcursion.com/members/little-kid-wit-bass.html Youngest active user on ROE Link to comment Share on other sites More sharing options...
KenC210 Posted October 7, 2011 Report Share Posted October 7, 2011 No. It will see .5 ohms. What he says^^^ your amp makes it easier to wire 2 subs to a smaller ohm load on the mono amp with the 4 terminals. nice option in an amp IMO Quote Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra Link to comment Share on other sites More sharing options...
Kranny Posted October 7, 2011 Report Share Posted October 7, 2011 wiring each coil to each set of speaker terminals will make the amp parallel the two. so .5 ohms. Quote Link to comment Share on other sites More sharing options...
little-kid-wit-bass Posted October 7, 2011 Report Share Posted October 7, 2011 I didnt get the point of it at first. Its still a mono amp. There's 2 + and 2 - There just the same terminal connected to each other. So when you connect each coil, either on the sub or the amp, it will be a .5 load. Quote I cant afford anything... forum.realmofexcursion.com/members/little-kid-wit-bass.html Youngest active user on ROE Link to comment Share on other sites More sharing options...
Chris661 Posted October 7, 2011 Author Report Share Posted October 7, 2011 thanks guys. pretty much clear it all up.. thanks!! Quote http://www.youtube.com/user/EAZYCHRIS?feature=mhee Link to comment Share on other sites More sharing options...
