160db in the low 20hz range
  • Replies 132
  • Created
  • Last Reply
On another note, If you bring be a suburban and $1,000,000, I will have it doing a 160 at 10hz for you. =@
Tuned in. Got a friend doing 156s at 28hz on here and gary killian can do 58s 59s below 20
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
On a burp but would like it to be able to bassrace a 159.9 fairly low to. It would cost a lot but wanted to know If it was possible without an extreme vehicle?
it is possible im sure.
but accounting for the time and money spent on the build its not plausible.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
I hear dbs are directly proportional to how many stickers you have on your windows.
This may or may not help.
Old Setup
03 DurangoRF Power T1 6.5 CompsMids/Highs Amp: AQ4x90Sub Amp: AQ 3500.1DSubs: 2 DC XL 18sBox: 12ft^3 tuned to 33HzMechman 270 Amp AltXS 6500XS 3100 x2
Highest Score to date: 151.2 db @ Headrest
Is gary the guy in the white excersion and tows it to shows?
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
Yes.
And IIRC, he once said he tows it to shows because it is cheaper than actually driving it to the show.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
i wouldnt bother why does it have to be tuned so low
Red light rev ya engines..light goes green u take off, petal to the floor.I take it slow but some how seem to catch up with u at he next red.So u think u can do it again.light goes green you stall..i put my foot down just to show u what fast really looks like :)
  • Who's Online   0 Members, 0 Anonymous, 263 Guests (See full list)
