160db in the low 20hz range
because low is a challenge
Hammerdown... 1%
  • Replies 132
  • Created
  • Last Reply
Possible.
I got close years ago. Back in 04
Truck played to 10
And with only 8-12's and 8k
On another note, If you bring be a suburban and $1,000,000, I will have it doing a 160 at 10hz for you. =@
Tuned in. Got a friend doing 156s at 28hz on here and gary killian can do 58s 59s below 20
am I your friend doing 156 at28hz?. Think it was 27hz.maybe wasn't me.or im full of it
No idea of the score at 10.
It would play down there is all.
We saw a 58 from 17-30
Vids on youtube
Xxx truck
The first version we did
8-re 05 xxx 12's and 8 planet audio bb1250's
Vids on youtube
Xxx truck
I'll ask the stupid question.
Why do blow throughs almost always play stupid low?
Is it because of the fact that it's a blow through, or because most people that do them only do them after having been in audio for fuck tons of time?
Combination of both?
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
Sorry for wrong info and yes its you :-)
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
  • Who's Online   0 Members, 0 Anonymous, 291 Guests (See full list)
