Mechman Alternators
little help with my alt please
so, i got my mechman a few months ago, installed it after 5 hours of banging the old one out and grinding down the mounting feet on the new one to get it to fit(it was slightly off, bench grinder ftw) anywho....i have 2 xs d2400's backing up my DC3.5k which is wired down to .5, now for the annoying kicker...my jeep charges at 13.6, so cold startup im sitting 14.3 then it drops and levels somewhere between 13.9-14.1, after driving for a bit it drops down to 13.5, but kicks right back up once i tap the gas, BUT heres my problem, i drop to freaking low 11's full tilt, wtf? whats the problem here? i have 0g from the alt stud to the + on the batt, mounting stud to - on the batt, then - on the batt to the frame, now i cant remember if i sanded down where i put the ground on the alt, but i wouldent think that that could cause that huge of a problem, i also dident use the given lug for the + run that mechman provided, again i couldent see this as much of a problem, 3rd, i have my back batts running of the alt itself, youd think itd be a bit better, even with my amp running @ 2ohm i get roughly the same drop at full tilt, im mind boggled here, its a 270amp unit** 02 jeep grand cherokee laredo inline 6
Edited by Freshman6969
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
Wired to .5 yourprob drawing 325-350 amps and have a 270amp alt
Not rocket science
You said you didnt use the lug provided, so what did you use??
Guess you figured he adds it cause he doesnt know what he's doing.
i had to have my mechamn sent in for repair ...they said because i used the wrong size o ring terminal (lil big)it messed mine up...it did melt the plastic around that terminal...so i would check that a.s.a.p also you always want to take your grounding points to bare metal ...if you worried about rust spray paint after u tighten it down.... i would also take a ground from the frnt bat to the fire wall as well as the frame to fire wall...im guessing your running you other batts grounded to the body...more thing have you charged ur bats recently?
Edited by extremeauto
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
Im guessing hes not actually charging
The post is the only real output from the alt, so whoknows wtf hes got goin on
Im suprised freshman... your not a newb here
im an electrical noob, thats my downfall, MECP my ass :shrug: , i have 2 runs front to back 1 neg(off the front batt to the back batt), 1 pos off the alt, i think ill freeze my ass off tom. and find this lug and use it, unless my dumb ass used it for something else >.>, either way THAT lug will be going on the alt, ill be checking if i sanded down the ground point on the alt, if i dident, thatll be coming off, i have the batts grounded in the spare tire well also, i checked both grounds with a dmm and both read .01 so thats perfect, even when i was at 1 ohm with my other set of 15's i was yeilding roughly the same numbers as the .5 and 2ohm wiring
also, anytime im not using my single plug outside the batts ARE infact on a charger, and all night before shows
also @ ray, i used the lug i already had on all my big 3 wires, it fits on there perfect
i think ray thought that you didn't use the post the copper lug was on. But extreme auto said that he messed his post on the alt up by using the wrong terminal like you might have so maybe you should look into that not saying its to late to fix but if your gonna change to the one they sent you might as well look at the post while you are there
that was my plan, it just popped into my head after scrolling through youtube and seeing all these people running such small amount of batts and around the power i have and a 270amp alt and keeping in the low 13's full tilt, made me think, well shit i did something wrong here
i mean my alts been in for awhile now, about the 2nd day after i got it, i might run to autozone and get it tested, if itll read that high, i know how some dont, maybe ill get lucky
right on maybe do the autozone first if you can that way when you fix you could see how much better it gets :good:
  • Who's Online   1 Member, 0 Anonymous, 198 Guests (See full list)
