FreeZzy Posted December 24, 2011 Report Share Posted December 24, 2011 Hello, i need help to set my gain, subsonic and low pass for my Hifonics BRZ2100.1D (i have a DC LVL 4XL 15 with 4cf box and tuned at 31hz and a pioneer 7200SD) So currently i put my gain at 2pm, my subsonic at 10am and same for low pass ... thanks Quote Link to comment Share on other sites More sharing options...
Babyjuice Posted December 24, 2011 Report Share Posted December 24, 2011 I just "attempted " to set my subsonic and low pass filter today. It sucks that hifonics didn't make more marks for.setting these (quarter marks would have been good atleast) but I tried to set them as good as I could. What I read on here is, set the subsonic to where you want the lowest hrz to play and set the lowpass to where you don't want it play above a certain hrz. For me for example my box is tuned to 32 hrz so I set it where it wont play anything below 27 hrz and it.won't play anything above 80 hrz. Hope this helps. Maybe someone can.correct me if.im wrong. Ps. Sorry.for all the.periods. im.on mobile :/ Quote BABYJUICE Link to comment Share on other sites More sharing options...
matt14 Posted December 24, 2011 Report Share Posted December 24, 2011 With gain, you can adjust a couple of ways. The way that most on here ( including me ) will recomend is to use the SMD DD1, which detects distortion and is honestly the easist tool to use. Others may recomend to scope the gains which is also a good way to do it. From there, it would be a guessing game. Some have the theory of 3/4- not good. Others may say to use a DDM, which is not accurate. As far as setting your low pass and sub-sonic, adjust the subsonic to 26/27hz ( rule of thumb is 5hz below box tuning ) and low pass to 80hz ( once again rule of thumb), but some may want a little higher or lower, really depends on what you like. I have no clue where 2p.m. and 10a.m. is on your amp, but what is suggested is where i would put them. Quote 2006 GMC YukonPioneer HU SHCA ran throughout Crescendo BC3500 One 18 AA Mayhem in a 4th order ZED Levithian 6 channel Rainbow Dual 6.5 comps ran Activehttp://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3 Link to comment Share on other sites More sharing options...
FreeZzy Posted December 25, 2011 Author Report Share Posted December 25, 2011 (edited) thank you both ! But I let my gain at 2 pm I have a one more question, i have a Low pass Filter for subwoofer on my Pioneer 7200SD, can i use it to adjust low pass ? ( example i put the low pass on amplifier at maximum and put 80 hz on pioneer 7200SD " same like a home theater subwoofer " ) ? thanks Edited December 25, 2011 by FreeZzy Quote Link to comment Share on other sites More sharing options...
Tek18 Posted December 26, 2011 Report Share Posted December 26, 2011 i am also trying to get mine to 27HZ and my high end to 80HZ i just do this by looking? i believe the rub1600D goes from 10hz to 50hz and the high end goes from 50hz to 150hz ... kind of a wide range of motion Quote Link to comment Share on other sites More sharing options...
