Overcoming cabin peak
Doing a build in a truck. I've tried many different boxes, small, big, tuned low, tuned high but no matter what the notes around 45 hz and up are pitiful. The low notes, low and sub 30 are the loudest.
So how can I fix this? Sure low notes are cool but playing all music is better than playing only super low stuff
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
what kind of truck? Subs, amp, more info.
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
6th order :peepwall:
Vehicle: 2008 Mustang V6
Exterior: Blacked Out Taillights, Turn Signals, Side Markers-Black 18x8 Enkei ls5-6000k HID's
Interior: Blue LED Strips with Module for Music-Hardwired Beltronics RX65 with Blue LED and remote button
Sub: 2 10 inch custom subs
Amp: Hifonics BRz 2600
Wire: Knu 0 gauge
Headunit: Kenwood kiv-bt901
Damplifier: Fatmat Rattletrap
Electrical: Stock Alt/Stock Battery/Big 3
its a 2002 chevy silverado
the rest of the info you requested is useless since we have this issue regardless of type of sub, number of subs, size of subs, box, tuning, orientation, and even power
6th i may consider
midbass drivers wont be able to keep up at that low of a frequency. they would need to take over at 45 hz and about 140 db (not much but for a midbass driver it may be a bit of a stretch lol)
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Probably have the best luck going bandpass if you are having a tough time getting to the higher 'more musical' notes. A 4th order would be a fairly easy way to get what you are looking for, though I do personally love my 6th order, as I get a near perfectly flat response from about 25 up to 50.
What sub(s) are we talking about though?
Need Test Tones/Sine Waves? Click Here!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Pioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE Audio
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Hit me up on Facebook, if you want
at this point he has two AB XFL 15s
(it changes often though)
Edited by IH8PunkRok
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
So it says that you have Hertz ESK 130, that's a 5" components, those usually start to kick in at 80-100Hz I'd say your gap is upper in frequency also, after all you said you tuned high and it didn't fix it looks more a gap in the 50-90 Hz region and not much below.
I don't think going bandpass will help you with your problem, do you know for real the exact specs of the box you are using now??
whats the box config.? i know in my truck, 2 18 Fi btls on an AQ3500.1 subs forward port up, it would play down to 20hz no problem.. ( tuned to 34) so, i cut the port down and tuned it to "42hz" ( on paper) and i brought peak up to 29 and also had a peak around 46 or so as well..
subs forward port up seems to work best in my truck ( before i walled it)
subs up port side also seemed to work ok
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   1 Member, 0 Anonymous, 1785 Guests (See full list)
