Cardboardcat15 Posted January 29, 2012 Report Share Posted January 29, 2012 Like the title says, are these welds any good? I don't know anything about welding so I can't judge them. I went through my normal mechanic who does work on all of my families cars, and seeing as how we've never had a single problem with his work, I trusted him with the welding. I just want to know if these are up to par so I can figure out whether or not I should have him do more welding with this bracket, or on my car in general. The reason I'm asking is because one of the arms of the actual bracket split in another spot (where he didn't work on), and I want to know if I'm safe to have him weld that part back on. Not bashing his work at all, he's an amazing mechanic, I'm just trying to be a "smart shopper" so to speak. There are pictures of the broken arm in my build log in my sig. All help is appreciated. http://www.youtube.com/watch?v=6aOdGySE-CE&feature=youtu.be and some pictures Thanks guys. My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/ Link to comment Share on other sites More sharing options...
Azagtoth502 Posted January 29, 2012 Report Share Posted January 29, 2012 No. pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls Link to comment Share on other sites More sharing options...
CleanSierra Posted January 29, 2012 Report Share Posted January 29, 2012 Looks like a cold joint....I don't think I'd have him weld anything else. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
audiofanaticz Posted January 29, 2012 Report Share Posted January 29, 2012 I myself think they are very sloppy and booger like welds. I can do better welds with my cheap harbor freight welder that jams every 3 seconds, and im not a welder. Link to comment Share on other sites More sharing options...
pimpnFosgates Posted January 29, 2012 Report Share Posted January 29, 2012 nuh uh. he didnt clean or heat metal enough. dont bond too good. learn to do it yoself n no worries buddy Lucky Durango Sony hu 4 croosfire 6.5mids crossfire 600.1 mono amp American bass 1280.4 mids and highs amp aq hdc3 12 2.4 cube net box, tuned to 34 and 14.4 inches of port per cube Link to comment Share on other sites More sharing options...
audiofanaticz Posted January 29, 2012 Report Share Posted January 29, 2012 Looks like if you would of shaved the spacer down that goes between the alt and the alt bracket, you could have fit the alt without having to cut the alt bracket and move it back. LMAO Link to comment Share on other sites More sharing options...
bass_stalker Posted January 29, 2012 Report Share Posted January 29, 2012 yeah those are some shitty welds. they should be some smooth continuous beads JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow. Link to comment Share on other sites More sharing options...
Cardboardcat15 Posted January 29, 2012 Author Report Share Posted January 29, 2012 Looks like if you would of shaved the spacer down that goes between the alt and the alt bracket, you could have fit the alt without having to cut the alt bracket and move it back. LMAO Well it wasn't an actual issue of width, it was clearance. The casing was too large to fit under the bracket in it's stock position. Even after shaving off some of the under side of the bracket, we still couldn't get it to fit. That's when we figured the only way it was getting on was by moving the bracket itself. I think I'm just gonna have him weld up that small part for now so the car is drivable, then once I save up the money head to DC power to get a whole new bracket done. =/ My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/ Link to comment Share on other sites More sharing options...
Nine8SST Posted January 29, 2012 Report Share Posted January 29, 2012 Negative....a good weld should look like a roll of nickles flattened out....like this.... 1998 SS/T Ram Build Log - Kenwood KVT-514 and KNA-G510 Navigation - 2 DC Level 3 12" - Components??? - Sundown ??? - Sundown??? - Knu Konceptz - Second Skin Dampy Pro - XS D6500 Link to comment Share on other sites More sharing options...
Cardboardcat15 Posted January 29, 2012 Author Report Share Posted January 29, 2012 Negative....a good weld should look like a roll of nickles flattened out....like this.... Ahh...ok. Thanks man. This makes me regret not taking ROP welding in highschool LOL My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/ Link to comment Share on other sites More sharing options...
