CE Auto Electric Supply
Will these also turn on LEDs with you remote turn on without damaging them??
It will not. Tell me what you want and I will build it. LEDs can only handle so much voltage (typically 2 volts or less) before being damaged by overcurrent. What color LEDs do you want and for what purpose? I will design a circuit to do exactly what you want.
Just underglow, and LEDs in my box
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
OK, I see. If you are switching those things ON currently, then yes, this will do that automatically when you turn your system on. I thought you were discussing raw LEDs.
What size fuse do these things require? I may have to make you a special version that is designed to handle additional current.
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
good deal on that!!
Follow my Tweet (Twitter)
my amp turn on light is on even when its off, you think i have weak turn on led? im looking into getting the deluxe since i will be powering up many amps
yes
edit: my eq turns off and so does my epicenter but the light on the bass amps dont
Edited by Miguels
Then it is not a problem with the amplifier or the LED. It sounds like you have some residual voltage on the turn-on output keeping the LED lit. I have seen this before. This can be the result of some component backfeeding voltage into the turn-on circuit. In some cases, it will even keep the radio ON after it is turned off. This is a job for your digital multi-meter.
does the smd discount work on just these or can it work for the stuff on your site as well?
you have alot of interesting stuff on there i like the "add on" fuse panels
and to other people, if u run alot of stuff off your acc wire, such as, aux lighting and what knot this kit will also work too
oh, and a little off topic but with a spdt relay and a signal flasher, can i make a cheap wig wag setup? like to flash lights back n forth?
There are two problems with doing that. One - it is illegal to make your headlights flash back and forth like that on public roadways. Second - a flasher is a thermal device. So, as it heats up, it will flash more and more rapidly. I used to do service work on lots of police vehicles and they all used a solid state device called a Street Sweeper. You might look into it.
i was gunna build something for a friend thats a firefighter, gunna use red n amber trailer lights to put in his back glass, thankx for posting
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
  • Who's Online   0 Members, 0 Anonymous, 237 Guests (See full list)
