Broke_Audio_Addict Posted May 25, 2017 Report Share Posted May 25, 2017 Timing chains can still jump timing. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
Quiet Posted May 25, 2017 Report Share Posted May 25, 2017 I've had 3 cars with timing chains, never with a chain replacement, 2 went over 250k and the last one at 180k... never an issue with timing. Maybe if the moon's align and rainbows appear in the night would it happen, but it's probably less common than throwing a rod. Speaking of throwing a rod (i was so pissed) I did have a 95 cougar once with a 4.6L, floated the valves because the computer shifted the transmission into 1st a few times at 70. That one ended up dropping a valve into the cylinder and eventually broke a rod. The motor STILL ran with 7 cylinders and otherwise hadn't jumped time. 2007 Pacifica Rebuild. Less quiet. Still not loud. Link to comment Share on other sites More sharing options...
SnowDrifter Posted May 25, 2017 Report Share Posted May 25, 2017 ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
SnowDrifter Posted May 25, 2017 Report Share Posted May 25, 2017 3 hours ago, srp365 said: I've had 3 cars with timing chains, never with a chain replacement, 2 went over 250k and the last one at 180k... never an issue with timing. Maybe if the moon's align and rainbows appear in the night would it happen, but it's probably less common than throwing a rod. Speaking of throwing a rod (i was so pissed) I did have a 95 cougar once with a 4.6L, floated the valves because the computer shifted the transmission into 1st a few times at 70. That one ended up dropping a valve into the cylinder and eventually broke a rod. The motor STILL ran with 7 cylinders and otherwise hadn't jumped time. Haaaaaaah timing chains aren't worth a damn any more Be like VW. If the engine rotates backwards it skips teeth. i.e. don't leave it in gear on a hill Also wasn't that OHV? Lot of the new ones are OHC. Need tensioners and guides and whatnot. Little different gig now ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted May 25, 2017 Report Share Posted May 25, 2017 The ticking is probably a lifter. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Quiet Posted May 25, 2017 Report Share Posted May 25, 2017 Pushrod V8 ftw. Think I'm.closer to just getting an old square Chevy I can work on. 2007 Pacifica Rebuild. Less quiet. Still not loud. Link to comment Share on other sites More sharing options...
Quiet Posted May 25, 2017 Report Share Posted May 25, 2017 9 hours ago, ShadeTreeMechanic said: The ticking is probably a lifter. Yeah, didn't sound like timing went all to shit, but then again, it never ticked before it threw the code. Wondering if when it jumped a valve kissed a piston and knocked a lifter loose. 2007 Pacifica Rebuild. Less quiet. Still not loud. Link to comment Share on other sites More sharing options...
Kyblack76 Posted May 25, 2017 Report Share Posted May 25, 2017 5 minutes ago, srp365 said: Pushrod V8 ftw. Think I'm.closer to just getting an old square Chevy I can work on. WORD!!! And same here bro.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Kyblack76 Posted May 25, 2017 Report Share Posted May 25, 2017 9 hours ago, SnowDrifter said: El Ohhhhh Fucking El SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Quiet Posted May 25, 2017 Report Share Posted May 25, 2017 Well, found the cause... Anyone wanna guess as to wtf happened here? 2007 Pacifica Rebuild. Less quiet. Still not loud. Link to comment Share on other sites More sharing options...
