Rockford96 Posted December 30, 2016 Report Share Posted December 30, 2016 Pretty sure the head gasket in my truck is leaking loosing coolant and its not leaking any on the ground having it tested monday but it it does need one im having headers and maybe a cam put in at the same time so thats good My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu Link to comment Share on other sites More sharing options...
3vil Posted December 31, 2016 Report Share Posted December 31, 2016 Moved into a new place today. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted December 31, 2016 Report Share Posted December 31, 2016 23 hours ago, Rockford96 said: Pretty sure the head gasket in my truck is leaking loosing coolant and its not leaking any on the ground having it tested monday but it it does need one im having headers and maybe a cam put in at the same time so thats good What motor? Might as well add timing chain and water pump. Maybe a set of rocker arms and valve guide seals? Heavier valve springs? Intake manifold? The list just gets longer and longer. lol 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
boom50cal Posted January 1, 2017 Report Share Posted January 1, 2017 Flipped the rzr today. Was odd sitting in the seat buckled in and seeing the earth at a 90* angle. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole. Link to comment Share on other sites More sharing options...
Quiet Posted January 1, 2017 Report Share Posted January 1, 2017 1 minute ago, boom50cal said: Flipped the rzr today. Was odd sitting in the seat buckled in and seeing the earth at a 90* angle. did it survive? 2007 Pacifica Rebuild. Less quiet. Still not loud. Link to comment Share on other sites More sharing options...
boom50cal Posted January 1, 2017 Report Share Posted January 1, 2017 Just now, srp365 said: did it survive? yessir. Cracked the front and rear fenders, bent my roof a little. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole. Link to comment Share on other sites More sharing options...
Quiet Posted January 1, 2017 Report Share Posted January 1, 2017 2 hours ago, 3vil said: Moved into a new place today. this post is underrated. 2007 Pacifica Rebuild. Less quiet. Still not loud. Link to comment Share on other sites More sharing options...
Quiet Posted January 1, 2017 Report Share Posted January 1, 2017 2 minutes ago, boom50cal said: yessir. Cracked the front and rear fenders, bent my roof a little. well if it's not getting banged up a little you aren't having enough fun. Glad you're okay. 2007 Pacifica Rebuild. Less quiet. Still not loud. Link to comment Share on other sites More sharing options...
boom50cal Posted January 1, 2017 Report Share Posted January 1, 2017 Just now, srp365 said: well if it's not getting banged up a little you aren't having enough fun. Glad you're okay. thanks man. i got a bruise on my stomach and thigh from the steering wheel. need a harness but radio is next lol On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole. Link to comment Share on other sites More sharing options...
mbdblue Posted January 1, 2017 Report Share Posted January 1, 2017 My DD amp's output is DOA....spent a few hours tweaking the wiring to fit before I knew. But at least I'll be getting a replacement. AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
