Zx2500 Amp Draw?
wrathchild281
I tried to look up past forums on this and had no luck. How much will a zx2500 draw at 2 ohms? Im gonna run 4 for a daily setup and im trying to figure out how many alts and what amperage alts i should run to properly supply these amps with enough amperage. thanks
225 Excessive Amperage Alt.
4 Yellow top batteries
Pioneer AVH-6600
Kicker KQ5
2 FI 18 BTL's fully loaded
2 zx 2500.1's
4 ks6.5 coaxials
4 ks5.25 coaxials
kx650.4
http://www.cardomain.com/ride/2358078
the lowest the zx2500 will do is 2 ohm and i know for sure it holds a 300 amp fuse.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
There was just another thread on here SMD, that said a few people have been able to run that amp at 1ohm daily, even tho its not rated at that, I doubt they upgraded thier fuses past 300... but I never owned one of those amps, or even installed that model amp
Im not asking if i can run it lower than 2 ohms. I already have the subs and amps so im set on running them at 2 ohm. My question is how much will they draw each. And the 300 amp fuse they have on them doesnt exactly mean they will draw 300amps.
Pioneer AVH-6600
Kicker KQ5
2 zx 2500.1's
4 ks6.5 coaxials
4 ks5.25 coaxials
kx650.4
i'm not really into how much the amp will draw but i'm sure you'd have to at minimum a 150 amp alternator for the amp to play properly.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 901 Guests (See full list)
