Erwindmac Suz Posted February 26, 2012 Report Share Posted February 26, 2012 hi everyone i have a question i just got my smd dd-1 in the mail yesterday and i was gonna tune my system and i was reading threw the manual on what i need to do. and i have a question i am doing the measuring a head-unit through an amplifier and i see it tells me to set my eq and crossovers on the head unit and amp to flat but my problem is there no way i can set the eq and cross over on my deck to flat and i am not sure what to do. head unit - eclipse cd5030 sub amp - plye drive plad 3300d 4 channel amp - rockford fosgate dsm4040 sub's - 2 12 inch sundown audio sa's dvc 2 ohm. Quote Link to comment Share on other sites More sharing options...
donpablo Posted February 26, 2012 Report Share Posted February 26, 2012 For the headunit just make sure the treb bass and if you have it sub vol to even Quote 2015 F-150 Platnuim Link to comment Share on other sites More sharing options...
Erwindmac Suz Posted February 26, 2012 Author Report Share Posted February 26, 2012 For the headunit just make sure the treb bass and if you have it sub vol to even sorry let me make sure i got this right for my headunit i wanna set my bass and terb and my sub control on my deck to even. Quote Link to comment Share on other sites More sharing options...
SnowDrifter Posted February 26, 2012 Report Share Posted February 26, 2012 For the headunit just make sure the treb bass and if you have it sub vol to even sorry let me make sure i got this right for my headunit i wanna set my bass and terb and my sub control on my deck to even. Set them to zero - set everything to zero. Turn of bass boost, no bass eq - nothing. Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Erwindmac Suz Posted February 26, 2012 Author Report Share Posted February 26, 2012 what about my deck i can turn my sub control bass and terb to 0 but on my cross over where i set my slope and my cross hz it won't go down to 0 even for my front and back speakers to. only thing i can do is bypass it by turning it up to 200hz and set my amp instead. Quote Link to comment Share on other sites More sharing options...
SnowDrifter Posted February 26, 2012 Report Share Posted February 26, 2012 Did you read the manual? It tells you to turn the crossover all the way up Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
MIKE-2U Posted February 26, 2012 Report Share Posted February 26, 2012 why cant you use it just through the rcas? i had that same problem, wasn't detecting signal so once i got to 1/2 volume it worked. easier then testing through the amp Quote 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd Link to comment Share on other sites More sharing options...
Erwindmac Suz Posted February 26, 2012 Author Report Share Posted February 26, 2012 why cant you use it just through the rcas? i had that same problem, wasn't detecting signal so once i got to 1/2 volume it worked. easier then testing through the amp how would i do this for all my stuff like my amp's and deck 1 Quote Link to comment Share on other sites More sharing options...
MIKE-2U Posted February 26, 2012 Report Share Posted February 26, 2012 plug rca into dd-1 find max volume. then use probs on the amp to find max gain on amp ? Quote 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd Link to comment Share on other sites More sharing options...
Erwindmac Suz Posted February 26, 2012 Author Report Share Posted February 26, 2012 plug rca into dd-1 find max volume. then use probs on the amp to find max gain on amp ? do i plug the red or black rca into the smd dd1 Quote Link to comment Share on other sites More sharing options...
