BEEMDUB Posted February 29, 2012 Report Share Posted February 29, 2012 Just a quick question Which would be better amp grounded to frame or the neg on the battery? I can do either just as easily because my battery's in my trunk Link to comment Share on other sites More sharing options...
uhoh_45 Posted February 29, 2012 Report Share Posted February 29, 2012 directly to battery- it goes directly to battery without having to to pass threw car R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
Toofast4u Posted February 29, 2012 Report Share Posted February 29, 2012 I personally like grounding to the chassis. Reason being is EVERY TIME I've grounded to my battery I'll get terrible whine. I actually have a charger too. The stock ground isn't bad, I'd try both and see which one you like more. Link to comment Share on other sites More sharing options...
Socky Posted February 29, 2012 Report Share Posted February 29, 2012 I'd ground it to the battery, if the battery is grounded to the chassis. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz Link to comment Share on other sites More sharing options...
BEEMDUB Posted February 29, 2012 Author Report Share Posted February 29, 2012 I personally like grounding to the chassis. Reason being is EVERY TIME I've grounded to my battery I'll get terrible whine. I actually have a charger too. The stock ground isn't bad, I'd try both and see which one you like more. Hmm thats what I was afraid of when you got the whine did you hear it out of your subs? Link to comment Share on other sites More sharing options...
watabeast Posted February 29, 2012 Report Share Posted February 29, 2012 to me it depends on the build...if its a small setup or in a car without a 2nd rear battery, the chassis is okay. I prefer to bolt it instead of self tapping screws. Id also rather go directly to the battery if you have a rear battery that is close to the amp. Link to comment Share on other sites More sharing options...
Toofast4u Posted February 29, 2012 Report Share Posted February 29, 2012 I personally like grounding to the chassis. Reason being is EVERY TIME I've grounded to my battery I'll get terrible whine. I actually have a charger too. The stock ground isn't bad, I'd try both and see which one you like more. Hmm thats what I was afraid of when you got the whine did you hear it out of your subs? Nope, only my mids and highs amp. The sub amp gave off no noise. Link to comment Share on other sites More sharing options...
Bmike Posted February 29, 2012 Report Share Posted February 29, 2012 i myself ground my amp to the battery and my batteries to the chassis 2007 trailblazer lthead unit- pioneer p4300dvd crescendo ft-1 supertweeters pioneer m650 pros audiocontrol 2xs crossover Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas Link to comment Share on other sites More sharing options...
uhoh_45 Posted February 29, 2012 Report Share Posted February 29, 2012 I personally like grounding to the chassis. Reason being is EVERY TIME I've grounded to my battery I'll get terrible whine. I actually have a charger too. The stock ground isn't bad, I'd try both and see which one you like more. do you have a pioneer deck by chance? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
Toofast4u Posted February 29, 2012 Report Share Posted February 29, 2012 I personally like grounding to the chassis. Reason being is EVERY TIME I've grounded to my battery I'll get terrible whine. I actually have a charger too. The stock ground isn't bad, I'd try both and see which one you like more. do you have a pioneer deck by chance? Yup, I never found a way around that stupid pico fuse problem. Link to comment Share on other sites More sharing options...
