making a hole bigger
So...if I was an existing hole in some wood...what would be the best way to make me bigger and keep me looking nice and round?
d(-__-)b
how big are you trying to go? and from what size.
You can always hole saw if you have one that big.
if its a sub cutout you could try jasper jigging a plug out to fill the cutout and then going to the bigger hole that way.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Jigsaw skills :) ...
There is not enough jigsaw skills in the world.
or a router
....yeah........and what bit?
Cutout is for a 10" speakers but now I need it flushed but the hole is already there.
Your saying just plug the hole, find the center and use jasper like I am cutting a new hole? That might just work....damn I gotta like 10 holes to re do....FUCK
d(-__-)b
X2
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
Some of you may settle for the jagged aftermath of a jigsaw...i cant do it.
d(-__-)b
so your trying to flush mount speakers on a double baffle im guessing? basically do it like you normally but take a board and run it underneath screw it in just enough to hold the board in place to run the router around..might work (and far enough away so the router doesnt hit it lol)
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
I messed up a flush mount once, plugged the hole with the circle I cut out, tacked it in with some brad nails, and ran the japser around, worked fine and looked clean.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
