678gobot Posted March 27, 2012 Report Share Posted March 27, 2012 I am currently having an issue with my sub. I've had it hooked up for about 5 days now and every time I crank it up, it gets hot, real quick. Anyone else having a similar problem with theirs? I have a dual 2ohm model wired at 1 ohm on my amp which is a Hifonics Brutus BRZ2100D. I also have a pair of RE Audio SXX 12's that I run on the same amp and do not encounter the same problem. Quote Link to comment Share on other sites More sharing options...
jmanjr82 Posted March 27, 2012 Report Share Posted March 27, 2012 more then likely your clipping it. Quote Link to comment Share on other sites More sharing options...
CJ18 Posted March 27, 2012 Report Share Posted March 27, 2012 Clipping. Getting hot is not an issue with the subs, it is an amp/enclosure issue. 1 Quote Link to comment Share on other sites More sharing options...
Trigg Posted March 27, 2012 Report Share Posted March 27, 2012 I am currently having an issue with my sub. I've had it hooked up for about 5 days now and every time I crank it up, it gets hot, real quick. Anyone else having a similar problem with theirs? I have a dual 2ohm model wired at 1 ohm on my amp which is a Hifonics Brutus BRZ2100D. I also have a pair of RE Audio SXX 12's that I run on the same amp and do not encounter the same problem. your running them all on the same amp together? Quote there is some VERY hard headed people out there. Anyone who says a DD-1 isnt necessary is also saying an O-scope isnt necessary. Anyone who says an O-scope IN THE MINIMUM isnt necessary, is a noob. Forget the DD-1 for a minute, any reputable installer will at LEAST use an O-scope. Those guys in that thread are clowns. Hard headed clowns. Link to comment Share on other sites More sharing options...
DTS909 Posted March 27, 2012 Report Share Posted March 27, 2012 Need more info on how you have your head unit, amp settings? Quote VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback Link to comment Share on other sites More sharing options...
bumonskateboard6 Posted March 27, 2012 Report Share Posted March 27, 2012 (edited) 3 mismatched subs on one amp? Sweet. Edited March 27, 2012 by bumonskateboard6 Quote Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also? Link to comment Share on other sites More sharing options...
Bmike Posted March 27, 2012 Report Share Posted March 27, 2012 (edited) im pretty sure thats not what hes saying, more on the line that he has ran the others on the same amp just a differnt time. you're ethier clipping or you have a box issue. Edited March 27, 2012 by Bmike Quote 2007 trailblazer lthead unit- pioneer p4300dvd crescendo ft-1 supertweeters pioneer m650 pros audiocontrol 2xs crossover Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas Link to comment Share on other sites More sharing options...
Freshman6969 Posted March 27, 2012 Report Share Posted March 27, 2012 im pretty sure thats not what hes saying, more on the line that he has ran the others on the same amp just a differnt time. this, your clipping ill put money on it Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
HunterJohnson Posted March 27, 2012 Report Share Posted March 27, 2012 CJ is a sale rep I'd listen to him. Sounds like a bad signal 2 Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
donpablo Posted March 27, 2012 Report Share Posted March 27, 2012 My lvl 3 m2 12's were getting a bit hot to but i just figured it was causei had been playing close to full tilt for 15 mins or so Quote 2015 F-150 Platnuim Link to comment Share on other sites More sharing options...
