Mechman Alternators
Voltage dropping to 12.8 at full tilt with 330 amp alt, four kinetik batts, four runs 0 guage , one optima up front.
Voltage dropping to 12.8 at full tilt with 330 amp alt, four kinetik batts, four runs 0 guage , one optima up front. I don't understand , but it only does it when I'm just sitting at idle. When I ride and play it it's fine, .voltage drop no less than 13.3V. Wat do I need to do???? I'm confused do I need more batteries , more runs of 0 guage ????
  • Replies 28
  • Created
  • Last Reply
Top Posters In This Topic
Popular Days
What amp? What impedience are you wired at?..I have 1020amps of alt..6 xs d1400 10 runs of 0g on 2 dc7.5s and I can drop instantly at idle but on freway cruising at 2krpm I only drop .2 of a volt fulltilt...most alts do nothing at idle an I found out turn on an off if your idleing and rev... so you can do more batterys that will help to at least keep you at battery voltage
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Look into an overdrive pulley.
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
i believe he said 2 sundown 3500s strapped at 1 ohm.. he made another thread like 5 mins ago
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
Hey wats up,,, two sundown strapped @2 ohms.. Crazy thing is I plan on strapping @1 soon, and that even more power.
  • Who's Online   0 Members, 0 Anonymous, 277 Guests (See full list)
