Everyday, we post a new deal of the day that ranges from installation accessories, to pro audio, to car audio. Each deal is well below our regular prices, and gives people a chance to get the item at awesome prices. Check back in this post day by day, as I will be updating it with new deals, or you can go to our homepage at
http://www.audiosavings.com where they're posted. You will also see our best sellers and other deals we have at the moment.
Today's AudioSavings deal is....
CLARION EQS746
(7 BAND 1/2 DIN GRAPHIC EQUALIZER WITH 7 VOLT PRE-AMPS + SUBWOOFER CONTROL, AND HIGH PASS AND LOW PASS CROSSOVERS + AUX INPUT)
The clarion EQS746 1/2 DIN 7 band Graphic Equalizer will allow you to fine-tune and adjust, your sound system, until it gets perfect sound. This equalizer has subwoofer controls, and built-in high pass and low pass crossovers.
This equalizer is made by the most trusted brand in the industry, and it will do what it is supposed to do when you plug it in. It will allow you to adjust the frequencies, and the loudness of the mids, highs, and lows coming out of your speakers.
Features:
  • 7 Band 1/2 din Equalizer with rotary controls
  • 12 dB Boost/Cut adjustable @ 50 Hz, 125 Hz, 345 Hz, 750 Hz, 2.2 KHz, 6 KHz, and 16 kHz
  • Adjustable AUX input sensitivity
  • Rotary volume control
  • 6 channel RCA outputs
  • AUX input w/ source select switching
  • Sub output
  • Sub level control
  • Gold plated pre-amp inputs
  • Gold plated pre-amp outputs
  • Rotary fader controls
  • Selectable 60/90 Hz Low-Pass Crossover
  • RCA Jack
  • Signal-to-Noise Ratio 105dB
  • Frequency Response 10-50,000Hz
  • 7 Volt Line Driver
PRICE: $52.95
http://www.audiosavings.com/audiosavings-day-deal/index.aspx?item_cd=EQS746
Edited by AudioSavings Dean
Link to post
